2005 2008 ford crown vic door trigger?
ls@pcs
Member - Posts: 6
Posted: June 18, 2008 at 1:39 PM / IP Logged
Hi , I need some help here . We are working on A bunch of 2005 and newer Crown Vics . We need the driver door trigger wire to trigger a function on our video system . All the info I have found tells me it's dark blue and inside the door . But it's not triggering our function right . Is this wire a low voltage trigger ? Do we need to use a relay ???? Any help would be GREATLY appreciated !!!!
Thank You .
Big Dog
Gold - Posts: 1,265
Posted: June 23, 2008 at 10:04 AM / IP Logged
No need to go inside door, no relays required.
You'll find the driver's door trigger down low in driver's kick in a brown plug. It's dark blue and will give a solid "negative" signal when the door's open.
The other three doors are common on a BLACK/ orange found under the drivers door sill plate. Also negative trigger.
Prepare your future. It wasn't the lack of stones that killed the stone age.
ls@pcs
Member - Posts: 6
Posted: June 23, 2008 at 2:49 PM / IP Logged
And this is on 05 and newer Crown vics ?
I looked in the kick panel and could not find the dark blue any where . I could only find it inside the door going into the door module .
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
