1100f
paddd
Posted: January 22, 2010 at 7:23 PM / IP Logged
Hi All:
I have a 2006 ford ranger and I want to install a directed electronics 1100f ford pats/securilok remote start interface data in it to work with my autostart remote starter can anyone explain how I wire this in?
thanks
Platinum - Posts: 7,828
Posted: January 22, 2010 at 8:44 PM / IP Logged
First, you will need two working, non-clone, keys to program the bypass.
Wire as follows:
1100F  Nine wire harness
        GREEN/ Red wire to IGN transponder plug pin 3 Gray/Orange wire.
          Gray/Red wire to IGN transponder plug pin4 WHITE/ Light Green wire.
         Pink wire to IGN transponder plug pin2.  This connection can also go to the main IGN harness Ignition wire.
1100F Four wire harness
        Red wire to +12v constant
         Black wire to ground
         Blue/White to Remote Start wire labeled as "Ground When Running"
Follow the install guide.  Do a factory reset first.  Then select install mode as Standard ( two flashes).  Then follow the programming guide for a Transponder Type 3.
Posted: January 22, 2010 at 8:53 PM / IP Logged
Here is the manual, if you don't have it:
https://www.the12volt.com/installbay/file.asp?ID=696
paddd
Posted: January 23, 2010 at 9:42 AM / IP Logged
Thanks guys this is the exact info I was looking for
