2008 ford sport trac wiring
CWayss
Posted: January 24, 2010 at 9:49 PM / IP Logged
Hello,
Looking for a wiring Diagram to a 2008 Ford Sport Trac
Looking to wire a DEI 562T Remote Start. Any additional info needed to install properly would be greatly appreciated!
The DEI wiring diagram would be prefered, and any of the DEI Fax's that show how to any handle any special needs would be great too.
Thank you!
CWayss
kanarrjl
Member - Posts: 30
Posted: January 25, 2010 at 11:51 AM / IP Logged
Remote Start
12 Volts-red(50A), yellow/red(50A), blue/red (50A)+SJB, black 32 pin plug (E), pins 32, 4, and 1
The SJB (Smart Junction Box) is under the driver dash.
Second 12 Volts-PURPLE / red(15A) ignition switch, black 7 pin plug, pin 4
Starter-blue/white ignition switch, black 7 pin plug, pin 7
Second Starter-N/A
Ignition-WHITE/ orange ignition switch, blk 7 pin plg, pin 1 or SJB, gry 32 pin plg (C), pin 26
Second Ignition-N/A
Third Ignition-N/A
Accessory-PURPLE / green ignition switch, blk 7 pin plg, pin 6 or SJB, gry 32 pin plg (C), pin 5
Second Accessory-N/A
Third Accessory-N/A
Keysense-blue/gray + ignition switch, black 7 pin plug, pin 5
Data Bus-yellow/orange (TX), PURPLE / gray (RX) data PATS Transceiver, black 4 pin plug, pins 3 and 4
The PATS(Passive Anti-Theft System) Transceiver is around the ignition key switch. The PATS ignition wire is WHITE/ orange in pin 1 and the ground wire is PURPLE / white in pin 2.
Can Bus High-gray/orange data data link connector, pin 3 or SJB, gray 32 pin plug (D), pin 16
The SJB (Smart Junction Box) is under the driver dash. The data link connector is under the driver dash.
Can Bus Low-PURPLE / orange data data link connector, pin 11 or SJB, gray 32 pin plug (D), pin 15
Can Bus Sw-N/A
Power Lock-gray / YELLOW - driver kick or SJB, black 32 pin plug (B), pin 27
Power Unlock-PURPLE / gray - driver kick or SJB, black 32 pin plug (B), pin 26
Parking Lights- (-)gray headlight switch or SJB, gray 32 pin plug (D), pin 3
The SJB (Smart Junction Box) is under the driver dash. May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 7. See Tech Doc 1096 for wiring information.
Parking Lights- (+) blue/white + driver kick or SJB, brown 32 pin plug (A), pin 11
Left Front Door Trigger-GREEN/ purple - N.C. driver kick or SJB, black 32 pin plug (B), pin 17
Right Front Door Trigger-white - N.C. passenger kick or SJB, blk 32 pin plug (B), pin 19
Left Rear Door Trigger-green - N.C. driver kick or SJB, black 32 pin plug (B), pin 20
Right Rear Door Trigger-yellow - N.C. passenger kick or SJB, blk 32 pin plug (B), pin 21
Hood Pin-N/A
Trunk/Hatch Release-N/A
Factory Alarm Arm-N/A
Factory Alarm Disarm-N/A
Tachometer-NOT purple ac any fuel injector
Brake Wire-PURPLE / white + brake pedal switch or SJB, brown 32 pin plug (A), pin 15
Parking Brake-gray/blue - parking brake switch or SJB, black 32 pin plug (B), pin 18
Horn Trigger-blue/white - horn switch or SJB, gray 32 pin plug (C), pin 6
that should be it
