vehicle speed sensor
dykuane
Member - Posts: 8
Posted: March 22, 2010 at 6:24 AM / IP Logged
Hello,
I have a Honda accord 05 american spec, the engine use to go off while the gear is on reverse specially when it is rainning or the wethear is cold. They say that it migh be the speed sensor that are malfunctioning.
Can someone help me locate them, or give me a suggestion.
There is a check engin light on and the diagnostic gave was the oxygen sensor from the exhaust.
thaks
Dydy
Posted: March 22, 2010 at 7:48 PM / IP Logged
Forget the speed sensor, follow up the diagnostic readings.
t&t tech
Platinum - Posts: 2,622
Posted: March 23, 2010 at 6:16 PM / IP Logged
So why not change the sensor that comes up on the diagnostic? That's why it's there, so "they don't have to say what it might be"!
91stt
Silver - Posts: 564
Posted: March 23, 2010 at 10:13 PM / IP Logged
Who is "they"?
You should always start with the diagnostic code.
As t&t says, that's what it is there for.
From your description, I would not change the O2 sensor right away.
Check the wiring for the secondary (downstream) O2 circuit first.
I suspect that you have a frayed wire.
t&t tech
Posted: March 24, 2010 at 8:34 PM / IP Logged
I think "they" would be the people who are wrongly diagnosing his problems! LOL!
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
