need 2007 honda pilot r/s
tianot
Copper - Posts: 155
Posted: May 24, 2010 at 11:57 PM / IP Logged
hey guys i need a installation image for 2007 honda pilot if you have one. is it easy to install a r/s for 2007 honda pilot? how can i connect the lock and unlock door to the r/s unit?
thanks
tianot
Platinum - Posts: 7,828
Posted: May 25, 2010 at 5:49 AM / IP Logged
Here is a link to Bulldog Security web site.  You can get the basic wiring guide there.   http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp    This site also has the wiring gude for your car.  Remember these wire listings are only a guide and all wires should be verified with a Digital Multi Meter.
Most Remote Start units directly support the Pilots Type B (-) door locks.    Check to see if your unit outputs a (-) negative pulse for Lock and UnLock.  The standard .7 second (-) pulse is fine.  After locating the correct wires in the car you can directly attach the R/S's lock & unlock wires to the cars wires.
tianot
Copper - Posts: 155
Posted: May 26, 2010 at 1:30 PM / IP Logged
hi! im using the fortin HONDA -SL3 bypass for 2007 honda pilot. do i need to hook up the ignition wire of the r/s unit to the vehicle?
on the installation guide of the HONDA-SL3 bypass,  the ignition wire of the vehicle is hook up to the yellow wire of HONDA-SL3. do i need to hook up the ignition wire of the R/S unit to the vehicle?
tianot
Posted: May 26, 2010 at 8:46 PM / IP Logged
The Fortin Honda SL3 Yellow wire goes to the RED / White ignition wire at the cars Ignition Barrel (same connector as the Security Lamp and Data wire).  The R/S's heavy gauge Ignition wire goes to the cars BLACK / YELLOW ignition wire in the ignition switch harness.
tianot
Copper - Posts: 155
Posted: May 27, 2010 at 8:43 AM / IP Logged
thanks bro!
tianot
