nissan micra 2010
ansari7715
Member - Posts: 8
Posted: November 01, 2010 at 3:15 PM / IP Logged
dear all do you have alarm wiring for Nissan micra lock & unlock wire please help
Ahmed ansari
Posted: November 02, 2010 at 5:26 AM / IP Logged
If it's the same as 07 on, remove dash top, it clips off after removing the "A" pillar trims. Top left is a processor, can't remember which plug but neg. probing with a meter and doors closed with key removed from ignition will activate lock unlock. N.B. It's also the pick-up point for indicators (hazards) door and trunk triggers (you will need to diode block away from this processor (see Ford/DEI 1076 on this site), power and ignition.
Posted: November 02, 2010 at 5:41 AM / IP Logged
Here we go, 07 40 way white connector
lock pin 6
unlock pin 25
Door triggers;
left front pin 29
right front pin 30
trunk/hatch pin 10
15 way black connector
left indicator pink/grey (?) pin A1
Right indicator RED / grey (?) pin A2
White 24 way connector
door triggers;
left rear pin 19
right rear pin 20
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
