2001 f250 diesel, viper 350
tfbike
Posted: April 13, 2011 at 3:35 PM / IP Logged
Hi, looking for help with wiring on my '01 F250, diesel, crew cab.
Putting in a viper 350 Responder. Specifically door lock/unlock wires, other wiring diagrams appreciated. I am a pro tech, just not a Ford/alarm tech!
Search in the forum comes up vague, so.
Thank you.
tfbike
Platinum - Posts: 7,828
Posted: April 14, 2011 at 5:46 AM / IP Logged
The door locks are either Type B (-) or Type C ( REV ) depending on whether or not the truck came with Factory
Keyless Entry.  Here is the info from Bulldog Security :
 POWER LOCK         PINK / YELLOW (TYPE C)           See NOTE *1   See NOTE *1
 POWER UNLOCK     PINK/LIGHT GREEN (TYPE C)   See NOTE *1   See NOTE *1
 NOTE *1 Vehicles with FACTORY KEYLESS ENTRY are a TYPE "B" Door locking system, wire are located in a GREY
Molex plug on the RIGHT side of the Steering column, vehicles without FACTORY KEYLESS are a TYPE "C" Door
locking system, when doing TYPE C Locks, use the DRIVERS side SWITCH when TESTING. Wires are located in the
DRIVERS DOOR HARNESS.
Wiring Diagram for Type B :  https://www.the12volt.com/doorlocks/page3.asp#3wp
Wiring Diagram for Type C :  https://www.the12volt.com/doorlocks/page3.asp#5w
Using a DEI 451M Relay Module will make things easier.  They are currently available "OnLine" for $5, delivered.  Here is a link to the 451M install guide :  https://www.the12volt.com/installbay/file.asp?ID=726
tfbike
Posted: April 14, 2011 at 8:11 AM / IP Logged
Thanks for the reply. I forgot to add it has factory keyless entry, but no security.
tfbike
Posted: April 14, 2011 at 4:28 PM / IP Logged
Factory Keyless Entry should make it easier.  Not familiar with the Viper 350 but most units can connect directly to Type B (-) vehicle lock wires.  If  the Viper has the Push / Pull ( + / - ) lock outputs, you might want to place a diode in line.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
