1999 Nissan Bassara Axis Stereo Wiring
fourustwentius
Posted: November 06, 2011 at 6:37 AM / IP Logged
OK, after using this site for a while it's time to give back. The following is the factory vehicle radio wiring for a 1999 Nissan Bassara Axis (Japan). Likely, this will apply to the Pressage and R'nessa as they are similar platforms.
Constant 12+                            Yellow (split into two wires out of harness)
Switched 12+                            Red (split into two wires out of harness)
Ground                                      Black (split into two wires out of harness)
Illumination                                Green - , Orange +
Dimmer                                     N/A (could be wrong, but I did not find one)
Antenna                                     Blue - (reads - when keys are turned to acc or on/start)
Speakers                                   +                                        -
Front Left                                   White                                WHITE/ Black Stripe
Front Right                                Gray                                  Gray/ Black Stripe
Rear Left                                   Light Green                       BLACK/ Yellow Stripe
Rear Right                                Yellow (not bright yellow)  BLACK/ Pink Stripe
Thanks for being here 12Volt! ;)
-Mike
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
