afermarket hu with stock monsoon system?
dougncin
Member - Posts: 15
Posted: March 28, 2012 at 9:07 PM / IP Logged
We have a 2002 Camaro with a Monsoon system. I hooked up new radio with a Metra harness and it sounds like crap I put the original back in and it sounds fine.
Is there a simple way to use the stock Monsoon amp with a Aftermarket head unit? I read other post but it doesn't seem totally clear. Is there an amp turn on wire or does it sense voltage over the speaker wires to turn on? Thanks for any info I can get.
Doug
Platinum - Posts: 13,719
Posted: March 28, 2012 at 9:30 PM / IP Logged
The blue wire of the 70-1858 is the amp turn on wire.
dougncin
Member - Posts: 15
Posted: March 28, 2012 at 10:40 PM / IP Logged
Thank you. WORKED
Saturday, August 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
