2009 Mitsubishi L200 Raging Bull Wiring
is200_turbo
Copper - Posts: 88
Posted: August 17, 2012 at 2:29 PM / IP Logged
Hi looking for any wiring information that might be available for a 2009 Mitsubishi L200 Raging Bull.
In specific
Alarm & remote Start
factory alarm Outputs
Factory alarm points to activate external units + or - Trigger for GSM Module
is200_turbo
Copper - Posts: 88
Posted: October 10, 2012 at 12:52 PM / IP Logged
Does this mean no one here has worked on the Mitsubishi l200 truck ?
is200_turbo
Copper - Posts: 88
Posted: October 20, 2012 at 7:16 AM / IP Logged
Ok so going through a technical manual this is the wiring i have identified can any of the guys on here confirm these are correct ?
Indicator Flash 1 - GREEN/ YELLOW (Cluster Loom)
Indicator Flash 2 - Green Orange (Cluster Loom)
rpm input - pin9 obd connector
door triggers - BLACK/ Red & BROWN / Yellow
Interior Light cable RED / Black
Door Lock - Blue/Black
Door Unlock - Blue/Red
Wait to start Lamp - BLACK/ white (cluster Loom)
Handbrake wire - Yellow (cluster Loom)
Brake wire - Orange (brake pedal)
The immobilisation wires and constant 12v can be identified at the ignition loom with my multimeter but providing all the above is correct for my model Mitsubishi L200 Raging bull
popobich
Posted: October 15, 2013 at 12:56 PM / IP Logged
Hi,
Could you do the alarm? I'm working on a 2012 L200 and would like to know how did you do with the factory central locking system, I'm trying to figure it out but haven't been able to find the lock/unlock wires in the car.
Any help would be appreaciated.
Thank you
