2013 Hyundai Sonata Alarm/Remote Start Wiring
meltingplastic
Copper - Posts: 225
Posted: November 04, 2012 at 11:26 AM / IP Logged
Hey guys,
Im looking for wiring info for a 2013 sonata... non push button(reg key). My mother lost her car in Sandy and just picked this up yesterday.
Driving a Bagged, Caddied 02 s10
shortcircuit161
Silver - Posts: 556
Posted: November 04, 2012 at 12:16 PM / IP Logged
Same as the 2012 model. I'm sorry to hear about losing the car from Sandy. But nice replacement. 2013 Hyundai Sonata Alarm/Remote Start Wiring -- posted image.
You shouldn't need an immobilizer bypass module as long as it's a US built Hyundai with regular key.
Search in the downloads section for Tech Tip 1300 for the door lock wiring. Fortin and Xpresskit also have a data module that will work the door locks.
2011-2016 Sonata
12volts      green (30A)      +      ignition switch, white 6 pin plug, pin 1
Starter      yellow      +      ignition switch, white 6 pin plug, pin 3
Second Starter      N/A
Ignition      pink      +      ignition switch, white 6 pin plug, pin 4
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange      +      ignition switch, white 6 pin plug, pin 2
Second Accessory      blue      +      ignition switch, white 6 pin plug, pin 6
Keysense      white      -      ignition key switch, white 6 pin plug, pin 4
Power Lock      white      -      dash fuse box, white 24 pin plug (D), pin 13
Power Unlock      yellow      -      dash fuse box, white 24 pin plug (D), pin 1
Notes: To unlock the driver door only, use yellow/orange (-) at the dash fuse box, rear, white 24 pin plug (F), pin 10.
Lock Motor      pink/black      5 wire      dash fuse box, black 39 pin plug (A), pin 34
Unlock Motor      red      5 wire      driver kick, white 56 pin plug, pin 11
Parking Lights+      GREEN/ black (L), BROWN / black (R)      +      dash fuse box, black 39 pin plug (A), pins 25 and 7
Parking Lights-      pink      -      headlight switch or BCM, gray 24 pin plug, pin 22
Notes: The BCM (Body Control Module) is under the driver dash, above the accelerator pedal.
Hazards      red      -      hazard switch, lt. green 6 pin plug, pin 2
Turn Signal(L)      blue/orange (F); blue/orange (R)      +      dash fuse box, blk 30 pin plug (B), pin 26; blk 39 pin plug (A), pin 8
Turn Signal(R)      RED / orange (F); RED / orange (R)      +      dash fuse box, blk 30 pin plug (B), pin 25; blk 39 pin plug (A), pin 12
Reverse Light      blue      +      driver kick, white 43 pin plug, pin 8
Door Trigger      brown      -      dash fuse box, white 24 pin plug (D), pin 7
Dome Supervision      yellow/black      -      BCM, white 18 pin plug, pin 4
Trunk/Hatch Pin      green      -      dash fuse box, white 24 pin plug (D), pin 4
Hood Pin      green      -      dash fuse box, black 30 pin plug (B), pin 27
Trunk/Hatch Release      white      -      release switch or dash fuse box, white 24 pin plug (D), pin 2
Power Sliding Door      N/A
Factory Alarm Arm      wht/org (key lock), brown (lock/unlock detection)      - and open      dash fuse box, white 24 pin plug (D), pins 15 and 22
Notes: See Tech Doc 1300 for wiring information.
Factory Alarm Disarm      orange (key unlock), brown (lock/unlock detection)      both -      dash fuse box, white 24 pin plug (D), pins 16 and 22
Disarm No Unlock      see factory alarm disarm
Tachometer      green, white, blue, or yellow      ac      front of engine, black 12 pin plug, pins 2, 8, 4, or 6
Wait to start      N/A
Brake Wire      green or GREEN/ orange      +      brake switch or driver kick, white 43 pin plug, pin 34
Parking Brake      orange      -      dash fuse box, bk 39 pin plg (A)(MT), bk 30 pin plg (B)(AT), pin 23
Horn Trigger      white      -      horn switch or driver kick, white 43 pin plug, pin 21
Rear Defrost     blue     -      BCM blue 20-pin Connector, pin 15
meltingplastic
Copper - Posts: 225
Posted: November 04, 2012 at 12:30 PM / IP Logged
Thanks a bunch!
Platinum - Posts: 7,828
Posted: November 04, 2012 at 6:18 PM / IP Logged
Here is a link to a Pictorial on a 2011 Sonata  :  https://www.the12volt.com/installbay/forum_posts.asp~TID~132478~PN~1
Everything in the Pictorial is the same for your 2013 Sonata except for the Defrost wire color.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
