2007 king ranch /klon
bat9905
Copper - Posts: 131
Posted: January 11, 2017 at 12:38 PM / IP Logged Link to Post Post Reply Quote bat9905
I've never used klon . I'm currently registered with web link and have a cable flashing modules but looking to use klon technology . Anything I should know before taking on this . I hate losing the install because the customer only has one key. Thanks for any help
bat9905
Platinum - Posts: 7,828
Posted: January 11, 2017 at 7:09 PM / IP Logged Link to Post Post Reply Quote kreg357
KLON works great! It's easier than doing the routine with two factory keys and hitting the remote start button.
Only two things to mention.
If you do "on-site" installs, make sure you have a good WI-Fi signal. I use a small laptop in the field.
I usually mate the R/S brain to the Bypass module during bench prep, so I leave the assembly in the vehicle during the KLON
process. I have to remember to allow some access room for pressing the button and disconnecting the harnesses, etc. The
small laptop sits on the drivers seat and the ADS USB cable reaches fine.
Other than that, it's real straight forward. Fortin's DCryptor process is a little confusing the first time you use it but
it works well, too.
bat9905
Copper - Posts: 131
Posted: January 11, 2017 at 9:54 PM / IP Logged Link to Post Post Reply Quote bat9905
Great!! thanks for the advice .
bat9905
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
