2000 Nissan Maxima (Factory Amp Turn On)
rotaryrx7
Posted: May 31, 2003 at 2:31 PM / IP Logged
As the title says I need to find out which wire on the harness that plugs into the factory Bose Amplifier is the turn on wire. I have tried searching around but haven't had any luck. Thanks in advance!
Dan
trusdamanr
Copper - Posts: 116
Posted: May 31, 2003 at 4:01 PM / IP Logged
use a multimeter,put a cd in and out until you find a wire that shows 0volts when the cd is out and 12 volts when the cd is on...if you use the radio youll prob find the power antenna wire which will show the same thing..
esmith69
Gold - Posts: 1,511
Posted: June 01, 2003 at 6:08 PM / IP Logged
If you're looking for a turn-on wire you can always just use the radio's +12 volt switched wire.  That'll show 12 volts only when the key is in the "ACC" or "RUN" position.
Ethan
Donate to the12volt.com
rotaryrx7
Posted: June 04, 2003 at 5:46 PM / IP Logged
Thanks for the responses. I did end up using the radio turn on, however it would still help me out to know which wire it is. Thanks for the advice!
Dan
