2011 Chevrolet Impala Wiring
nightowl2
Copper - Posts: 91
Posted: October 20, 2018 at 1:53 PM / IP Logged Link to Post Post Reply Quote nightowl2
I am installing a dash cam and need to know the wiring under the dash. I'm looking for + and acc specifically. My DVM stopped working and I haven't bought a new one yet. Can someone post the wiring for an alarm so it can help others as well?
geepherder
Platinum - Posts: 3,668
Posted: October 20, 2018 at 6:28 PM / IP Logged Link to Post Post Reply Quote geepherder
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=13&ModelID=20282
lurch228
Silver - Posts: 1,338
Posted: November 03, 2018 at 8:17 AM / IP Logged Link to Post Post Reply Quote lurch228
CHEVROLET IMPALA
MODEL YEAR(S
IMPALA 2009-2013
KEY T-HARNESS IMMOBILIZER
N/A N/A GM'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED/WHITE(+) (X4) @ BCM BLACK 25 PIN PLUG,PINS 1,2,3,4,
STARTER NOT USED FOR REMOTE STARTING!
STARTER 2 N/A
IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS or BCM, LT. GREEN PLUG, PIN 14, SEE NOTE #2
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BROWN (+) @ IGNITION SWITCH HARNESS or BCM, LT. GREEN PLUG, PIN 21, SEE NOTE #2
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) BROWN/WHITE (-) @ BCM, WHITE PLUG, PIN 8, SEE NOTE #2
PARKING LIGHTS ( + ) N/A
POWER LOCK PINK/BLACK (-) (TYPE B) @ BCM, GRAY PLUG, PIN 12, SEE NOTE #2
POWER UNLOCK ORANGE/BLACK (-) (TYPE B) @ BCM, GRAY PLUG, PIN 11, SEE NOTE #2
LOCK MOTOR WIRE GRAY (5-WIRE TYPE) IN DRIVER KICK, HARNESS TO REAR OF VEHICLE
DOOR TRIGGER TAN (-) @ BCM, GRAY PLUG, PIN 23, SEE NOTE #2
DOMELIGHT SUPERVISION GRAY/BLACK (+) @ BCM, PINK PLUG, PIN 1, SEE NOTE #2
TRUNK RELEASE LT. BLUE (-) @ BCM, WHITE PLUG, PIN 10, SEE NOTE #2
SLIDING POWER DOOR N/N
HORN TAN (-) @ BCM, BROWN PLUG, PIN 18, SEE NOTE #2
TACH SEE NOTE #3 @ ANY FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE LT. BLUE (+) @ BCM, BROWN PLUG, PIN 5, SEE NOTE #2
FACTORY ALARM DISARM PURPLE (-) SEE NOTE #4 @ BCM, PINK PLUG, PIN 20, SEE NOTE #2
ANTI-THEFT GM'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, See NOTE #1
NOTES
NOTE #1: This Vehicle is equipped with GM'S MULTIPLEX IGNITION/ANTI-THEFT SYSTEM that
Requires AN INTERFACE BYPASS MODULE to REMOTE START , Part # DBALL2 AND Part # RFLCHGM, Part # 779, ignition delay circuit is needed when installing an RS82, RS1100, or RS1200 and a DBALL2 or XK09 interface in a GM vehicle that has no starter/ crank wire coming from the ignition switch. To order please CALL 800 561 1110 ex. 2146 9 am to 5 pm eastern time, M-F. NOTE #2: The BCM is located UNDER the drivers dash and to the LEFT of the Steering Column.
NOTE #3: For the TACH wire on the V6, use any wire NOT PINK at any FUEL-INJECTOR, on the
V8 use any wire NOT PINK/BLACK (AC) at any FUEL-INJECTOR.
NOTE #4: This wire is only needed IF the alarm sounds when unlocking or Remote Starting, when testing this wire make sure you are turning the key in the drivers door key cylinder.
