2011 Ford Expedition, Remote Start Wiring
toofasttofocus
Posted: April 09, 2020 at 6:54 PM / IP Logged Link to Post Post Reply Quote toofasttofocus
Good afternoon. I am working on installing a remote start in my Expedition. I am installing a Avital 5305L with DB3. I looked for the wiring information under vehicle info but I could not find anything for this year. Yes I know there is a mod to use the factory remote start but I want to use a standalone system as I already had this one. Another thing is I would like to use the factory installed hood pin switch, does anyone know what the wiring colors are for this ? Any assistance in this matter would be greatly appreciated.
wirewise
Moderator - Posts: 489
Posted: April 09, 2020 at 7:07 PM / IP Logged Link to Post Post Reply Quote wirewise
Here's the wiring:
EXPEDITION     2009-2014
KEY     T-HARNESS     IMMOBILIZER
FDKEY-4     N/A     FORDS TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     RED (+)     @ SJB, BLACK 1-PIN PLUG (G) Pin 1, Note #2
STARTER     BLUE/WHITE (+)     @ IGNITION SWITCH, GRAY 10-PIN PLUG, Pin 10
STARTER 2     N/A
IGNITION 1     WHITE/ORANGE (+)     @ IGNITION SWITCH, GRAY 10-PIN PLUG, Pin 1
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     BROWN/YELLOW (+)     @ IGNITION SWITCH, GRAY 10-PIN PLUG, Pin 7
ACCESSORY/HEATER BLOWER 2     PURPLE/GREEN (+)     @ IGNITION SWITCH, GRAY 10-PIN PLUG, Pin 5
KEYSENSE     N/A
PARKING LIGHTS ( - )     Use Hazard Lights for (-) hook up GREEN/ORANGE     @ SJB BLACK 52 PIN PLUG(B) , PIN 48
PARKING LIGHTS ( + )     PURPLE/WHITE (+)     @ SJB, GRAY 13-PIN PLUG(E), PIN 6, Note #2
POWER LOCK     WHITE/BROWN (TYPE B)     in DRIVERS KICK PANEL or SJB, GRAY 26-PIN PLUG(C) Pin 17, Note #2
POWER UNLOCK     BLUE/BROWN (TYPE B)     in DRIVERS KICK PANEL or SJB, GRAY 26-PIN PLUG(C) Pin 4, Note #2
LOCK MOTOR WIRE     GRAY/BROWN ( 5-wire type)     in DRIVERS KICK PANEL or SJB, BLACK 32-PIN PLUG(D) Pin 6, Note #2
DOOR TRIGGER     GRAY/PURPLE (+)     Connect positive (+) door trigger wire from alarm to dome light supervision on car
DOMELIGHT SUPERVISION     GRAY/PURPLE (+)     @ SJB, GRAY 14-PIN PLUG(A) Pin 9, Note #2
TRUNK RELEASE     BROWN (-) (Liftgate), BROWN/YELLOW (-) (Glass), Note #3     @ SJB, GRAY 26-PIN PLUG(C) Pins 7 and 20, Note #2
SLIDING POWER DOOR     N/A
HORN     YELLOW/RED (-)     @ HORN SWITCH or SJB, BLACK 52-PIN PLUG(B) Pin 41, Note #2
TACH     Any wire NOT BLUE (AC)     @ Any FUEL INJECTOR
WAIT TO START LIGHT     N/A
BRAKE     YELLOW/GRAY (+)     @ BRAKE SWITCH or SJB, BLACK 52-PIN PLUG(B) Pin 40, Note #2
FACTORY ALARM DISARM     N/A
ANTI-THEFT     FORDS TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1     @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle is equipped with a Special Anti-theft key, to remote start you will need a Bypass module 791,(use this module IF you have a extra ignition key to place inside the 791 to remote start, if you do not have an extra key to use or wish not to have a key placed inside this bypass module, use Part # PKALL or PKFX, either one will work. If 2011-2014 and shaft of key has "SA" stamped into the metal this is Fords new 80bit key and will require a PKTX interface module
Note #2: The SJB, (Smart Junction Box) is located in the Passenger Kick Panel.
Note #3: TEST these wires while opening with the Handle on the Rear of the Vehicle. On vehicles with Power Liftgate the Open/Close wire is a GRAY/YELLOW (-) @ the Power Liftgate Switch on the Dash or in the DRIVERS KICK PANEL, Harness to Rear of Vehicle.
~wirewise~
toofasttofocus
Posted: April 09, 2020 at 7:57 PM / IP Logged Link to Post Post Reply Quote toofasttofocus
This is awesome information. Thank you for this. I am still wondering if anyone has the wiring info for the factory hood switch that is next to the coolant reservoir. I want to hook my hood pin switch wire up to this since it is already in a good spot on the hood and it will help with a cleaner install.
toofasttofocus
Posted: April 10, 2020 at 10:23 AM / IP Logged Link to Post Post Reply Quote toofasttofocus
I have installed alarms and remote starts in the past but I have never installed a bypass unit like the DB3. What all do I have to wire up from it to the car or the alarm remote start module? I know there is a data cable that goes between the DB3 and the Avital 5305 module.
Sunday, January 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
