2016 Hyundai Sonata, Alarm Wiring
avrohom24
Member - Posts: 31
Posted: November 09, 2020 at 10:53 PM / IP Logged Link to Post Post Reply Quote avrohom24
Hi, Im installing the Avital 4105 on a 2016 Sonata. The wiring is supposed to be the same as the 2011 Soanta, however its not. I was wondering if its the same as the 2017 Tucson as there is a wiring diagram for that. The wires Im missing for now are the Horn wire, Alarm Disarm, headlights, and Rear Defogger. Any and all help is greatly appreciated
ays
Platinum - Posts: 13,726
Posted: November 10, 2020 at 1:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Hybrid? Smart Key? Regular Key?
avrohom24
Member - Posts: 31
Posted: November 10, 2020 at 1:31 PM / IP Logged Link to Post Post Reply Quote avrohom24
Regular Key. Love your user name!
ays
Posted: November 15, 2020 at 2:53 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      red/orange (30A)      +      ignition switch, black 6 pin plug, pin 1
Second 12 Volts      red (40A)      +      ignition switch, black 6 pin plug, pin 5
Ground      (chassis ground)
Starter      yellow      +      ignition switch, black 6 pin plug, pin 3
Ignition      pink      +      ignition switch, black 6 pin plug, pin 4
Accessory      orange      +      ignition switch, black 6 pin plug, pin 2
Second Accessory      blue      +      ignition switch, black 6 pin plug, pin 6
Keysense      white      -      key switch, white 6 pin plug, pin 4
CAN Bus High      white (C-CAN)      data      OBD-data link connector, black 16 pin plug, pin 6      Directwire
CAN Bus Low      brown (C-CAN)      data      OBD-data link connector, black 16 pin plug, pin 14      Directwire
CAN Bus High 2      yellow (B-CAN)      data      SJB-dash fuse box, rear, white 32 pin plug (F), pin 9
CAN Bus Low 2      black (B-CAN)      data      SJB-dash fuse box, rear, white 32 pin plug (F), pin 10      Directwire
IMMO Data      blue/orange (EMS COM)      data      driver kick, white 47 pin plug, pin 19      Directwire
K Line      blue/black      data      OBD-data link connector, black 16 pin plug, pin 12      Directwire
Power Lock      white (w/o memory); (or use factory alarm arm)      -      SJB-dash fuse box, white 32 pin plug (H), pin 1
Power Unlock      yellow (w/o memory); (or use factory alarm disarm)      -      SJB-dash fuse box, white 32 pin plug (H), pin 19
Power Unlock - Driver Door      yellow/orange      -      SJB-dash fuse box, rear, white 32 pin plug (F), pin 5      Directwire
Lock Motor      gray/black      5 wire      SJB-dash fuse box, black 51 pin plug (D), pin 44
Driver Unlock Motor      white      5 wire      driver kick, white 77 pin plug, pin 52      Directwire
Passenger Unlock Motor      brown      5 wire      SJB-dash fuse box, black 51 pin plug (D), pin 26
Factory Alarm Arm      yellow (see Tech Doc 1300)      -      SJB-dash fuse box, white 32 pin plug (H), pin 5
Factory Alarm Disarm      blue (see Tech Doc 1300)      double -      SJB-dash fuse box, white 32 pin plug (H), pin 22
Lock Detection      brown (see Tech Doc 1300)      open      SJB-dash fuse box, white 32 pin plug (H), pin 10
Unlock Detection      (same as lock detection)      -
Parking Lights      green/black (L); brown/black (R)      +      SJB-dash fuse box, black 51 pin plug (D), pins 6, 5
Parking Lights -      blue/orange      - 1680 ohms      headlight/wiper switch, black 16 pin plug, pin 14
Parking Lights MUX      blue/orange      MUX      headlight/wiper switch, black 16 pin plug, pin 14
Hazards      red/black      -      SJB-dash fuse box, rear, white 32 pin plug (F), pin 13      Directwire
Turn Signal (Left)      blue/orange (F); blue/orange (R)      +      SJB-dash fuse box, white 20 pin plug (B), pin 18; black 51 pin plug (D), pin 30
Turn Signal (Right)      red/orange (F); red/orange (R)      +      SJB-dash fuse box, white 20 pin plug (B), pin 8; black 51 pin plug (D), pin 28
Headlight      blue/orange      - 5580 ohms      headlight/wiper switch, black 16 pin plug, pin 14
AutoLights      blue/orange      cut      headlight/wiper switch, black 16 pin plug, pin 14
Reverse Light      blue      +      driver kick, white 47 pin plug, pin 7      Directwire
Left Front Door Trigger      blue      -      SJB-dash fuse box, white 32 pin plug (H), pin 9
Right Front Door Trigger      white      -      SJB-dash fuse box, white 32 pin plug (H), pin 11
Left Rear Door Trigger      brown      -      SJB-dash fuse box, white 32 pin plug (H), pin 12
Right Rear Door Trigger      orange      -      SJB-dash fuse box, white 32 pin plug (H), pin 14
Dome Light      yellow      -      left front pillar, white 36 pin plug, pin 4
Trunk/Hatch Pin      black/orange      -      SJB-dash fuse box, white 32 pin plug (H), pin 13
Hood Pin      green      -      SJB-dash fuse box, white 24 pin plug (C), pin 3
Trunk/Hatch Release      white      -      trunk lid opener switch, 8 pin plug, pin 3
Trunk Release Motor      red      +      SJB-dash fuse box, black 51 pin plug (D), pin 41
Fuel Door Release      green/black      +      fuel lid opener switch, 8 pin plug, pin 5
Tachometer      blue/orange (2.4L, 2.0L-T); green (1.6L-T)      ac      camshaft position sensor on engine driver side, gray 3 pin plug, pin 3; black 3 pin plug, pin 2
Fuel Pump      green      +      driver kick, white 6 pin plug, pin 2
Rear Defroster      black/orange      - latched      SJB-dash fuse box, white 24 pin plug (C), pin 10
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      red      +      A/C Control Module, white 40 pin plug, pin 16
Right Front Heated Seat      brown      +      A/C Control Module, white 40 pin plug, pin 17
Speed Sense      green      ac      OBD-data link connector, black 16 pin plug, pin 3 or radio, white 24 pin plug, pin 16      Directwire
Brake Wire      green      +      driver kick, white 47 pin plug, pin 14      Directwire
Parking Brake      orange (without electric parking brake)      -      SJB-dash fuse box, white 24 pin plug (C), pin 13
Horn Trigger      yellow/orange      -      driver kick, white 47 pin plug, pin 35
Wipers      blue      +      driver kick, white 47 pin plug, pin 33
Left Front Window (Up/Down)      (motor is part of module)
Right Front Window (Up/Down)      orange - white (without auto up/down only)      A      driver kick (without memory); RF window switch, white 8 pin plug, pins 3 - 2 (with memory)
Left Rear Window (Up/Down)      gray - pink (without memory); green - yellow (with memory)      A      driver kick (without memory); LR window switch, white 12 pin plug, pins 1 - 4 (with memory)
Right Rear Window (Up/Down)      green - yellow (without memory); brown - white (with memory)      A      driver kick (without memory); RR window switch, white 12 pin plug, pins 1 - 4 (with memory)
Sun Roof (Open/Close)      yellow - gray (function with ignition on only)      -      panorama sunroof switch, black 6 pin plug, pins 2 - 3
Memory Seat 1      pink      -      driver kick, harness to rear
Memory Seat 2      blue      -      driver kick, harness to rear
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
