2019 Kia Soul, Rear Defrost Wiring
ftb_soup
Member - Posts: 14
Posted: October 21, 2024 at 10:40 PM / IP Logged Link to Post Post Reply Quote ftb_soup
Does anyone know which wire in the fuse box is the negative rear defrost? Ive read it is i/p-c 41 pin (pin 36) black/white wire. Im checking continuity to ground on all the wires while turning the defrost on and can not find it.
I think idatawire has the wrong info for the 2014-2019 rear defrost wire.
2017 soul, 2021 soul
lee.lopez
Copper - Posts: 309
Posted: October 22, 2024 at 9:13 AM / IP Logged Link to Post Post Reply Quote lee.lopez
2019 Kia Soul, Rear Defrost Wiring -- posted image.
ftb_soup
Member - Posts: 14
Posted: October 22, 2024 at 12:00 PM / IP Logged Link to Post Post Reply Quote ftb_soup
Thanks! So if Im understanding this correctly Im looking for I/P-G pin 6 black wire?
Or I/P-C pin 10 white wire? mea culpa im not proficient in wiring schematics.
lee.lopez
Copper - Posts: 309
Posted: October 22, 2024 at 1:10 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Not the black wire, that's just power for the indicator light at the switch.
The negative switched wire you want is either pink or white (depending if you have manual or automatic controls) between the rear defrost switch and the BCM. Look at the area in the red circle.
ftb_soup
Member - Posts: 14
Posted: October 22, 2024 at 9:45 PM / IP Logged Link to Post Post Reply Quote ftb_soup
So no latched (-) at the smart junctions fuse panel under the steering wheel? This compustar unit provides -250ma signal and Ive read "a" rear defrost/defog relay exists inside of that smart junction panel. completing ground.
lee.lopez
Copper - Posts: 309
Posted: October 22, 2024 at 10:02 PM / IP Logged Link to Post Post Reply Quote lee.lopez
You could also check for the white wire between the E/R Junction Box and the Smart Junction Box.
ftb_soup
Member - Posts: 14
Posted: October 22, 2024 at 10:12 PM / IP Logged Link to Post Post Reply Quote ftb_soup
thats pretty awesome, do you have a larger overall view of this system?
Ive found a wire in I/P-C (white) that completes ground when I trigger the defog/defrost button, but I want to be extra cautious before hooking this wire up. Everything else in the system is working as intended and this is the last wire.
Im leaning towards not even hooking it up atm.
ftb_soup
Member - Posts: 14
Posted: October 22, 2024 at 10:20 PM / IP Logged Link to Post Post Reply Quote ftb_soup
Here is what idatawire says for rear defrost for 2017 kia soul, but I certainly dont see a white 41 pin plug at I/P-C (C is a black connector and 36ish pins)
Once this jack daniels wears off and I have some light here, Ill check I/P-E for some sort of white (-) signal wire
lee.lopez
Copper - Posts: 309
Posted: October 23, 2024 at 5:24 AM / IP Logged Link to Post Post Reply Quote lee.lopez
ftb_soup
Member - Posts: 14
Posted: October 23, 2024 at 6:27 AM / IP Logged Link to Post Post Reply Quote ftb_soup
Thank you!
I think Im reading this right
