03 Saturn Ion Remote Start
n4tec
Member - Posts: 10
Posted: January 14, 2004 at 5:12 PM / IP Logged
 I need remote start wireing info if anyone has it. Thanks
boomer_106
Silver - Posts: 710
Posted: January 14, 2004 at 8:37 PM / IP Logged
ION 2003-2004
WIRE COLORSLOCATION
12 VOLTS CONSTANT
RED ( X2 )
IGNITION HARNESS
IGNITION 1DK. BLUEIGNITION HARNESS
IGNITION 2
SEE NOTES ( *1 )
IGNITION HARNESS        *SEE DIAGRAM*
ACCESSORY 1BROWNIGNITION HARNESS
STARTERSEE NOTES ( *1 )IGNITION HARNESS         *SEE DIAGRAM*
PARKING LIGHTS ( + ) BROWN AT HEADLIGHT SWITCH
DOOR TRIGGERSEE NOTES ( *2 )SEE NOTES ( *2 )
POWER DOOR LOCKWHITESEE NOTES ( *3 )
POWER DOOR UNLOCKSAME WIRE SEE NOTES ( *3 ) (TYPE B)
TRUNK RELEASEBLACK/ WHITE     ( + )AT THE BCM SEE NOTES    ( *4 )
TACH SENSORWHITE OR ORANGEIGNITION CONTROL MODULE ON TOP LEFT OF THE ENGINE, PIN B OR G
BRAKE
LT. BLUE ( + )AT THE BRAKE SWITCH
HORN
BLACK ( - )STEERING COLUMN
FACTORY DISARM
WITH FACTORY REMOTE
FACTORY ANTI-THEFTTYPEPASSLOCK 2 SEE NOTES ( *1 )  *SEE DIAGRAM*
     NOTES:
*1 - AT THE IGNITION SWITCH YOU WILL FINE A WHITE WIRE AND A WHITE/ BLACK WIRE. THE WHITE WIRE ACTS AS KEY SENSE, SECOND IGNITION, STARTER AND PASSLOCK. WHEN DOING A REMOTE START WILL NEED TO SEE THE DIAGRAM ON HOW TO A INTERFACE A REMOTE START.
*2 - THE DOOR TRIGGER HAS TWO WIRES, THE DRIVERS DOOR IS LT. GREEN/ BLACK PIN 45 AND THE PASSENGER DOORS ARE LT. BLUE PIN 44. THE BCM PLUG THAT THE DOOR TRIGGERS ARE IN IS C4. MUST DIODE ISOLATE EACH.
*3 - THE DOOR LOCK ARE AT THE BCM, LOCK IS A NEGATIVE TRIGGER AND UNLOCK IS A NEGATIVE THRU A 1.5K OHM RESISTOR. MUST USE RELAYS. PLUG C3 PIN 33
*4 - THE BODY CONTROL MODULE ( BCM ) IS PART OF THE FUSE/ RELAY BOX IN THE LOWER CENTER OF THE DASH, JUST BELOW THE HVAC CONTROL ASSEMBLY. THE BCM HAS FIVE PLUGS, C1 37PIN BLACK PLUG, C2 38PIN GRAY PLUG, C3 56 PIN BLACK PLUG, C4 56PIN GRAY PLUG, C5 6PIN GRAY PLUG.
Also see here
n4tec
Member - Posts: 10
Posted: January 14, 2004 at 9:31 PM / IP Logged
  THANKS!!!!
boomer_106
Silver - Posts: 710
Posted: January 14, 2004 at 10:34 PM / IP Logged
Your welcome. Hope the install goes good.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
