2004 Dodge Ram 1500 VSS
upholstery24
Posted: February 22, 2004 at 5:28 PM / IP Logged
Hi Folks,
I was hoping someone could share some knowledge. I need the location and color for the VSS wire on a 2004 dodge ram 1500. Thanks in advanced for all efforts.
02tracker
Posted: March 19, 2004 at 1:28 PM / IP Logged
For a 2003, 5.7L, (no info. available yet for 04), im showing a dark GREEN/ YELLOW wire on pin 13 of the PCM (located on right side of firewall).  It also joins up with a wire of the same color that goes to the ABS controller which is located in Left Rear of engine compartment.  Give that a try and let me know.
PEACE
Peace
upholstery24
Posted: March 22, 2004 at 3:45 PM / IP Logged
YO Tracker, Thanks for the reply. I found the wire shortly after posting the original post. If you are interested, here's the location and color of the VSS.
VSS Wire: ECM- RIGHT GREEN CONNECTOR POSITION 32, MANUAL 3 CONNECTOR ECM BLACK CONNECTOR POSITION 13
VSS Wire Color: AUTOMATIC LT. GREEN / WHITE or GREEN/ BROWN, MANUAL WHITE/ ORANGE or GREEN/ YELLOW
VSS Pulse: AUTOMATIC 38,600 MANUAL 8000
VSS Tach Wire: IF MANUAL TRANSMISSION USE CLUTCH SWITCH 250-4206
Tach Signal Wire Color: WHITE/ BLACK
Brake Switch Positive: PINK/BLUE
Brake Switch Negative: WHITE/ TAN
