2003 Dodge Sprinter Alarm/Remote Start Wiring
Buriy
Member - Posts: 9
Posted: May 18, 2004 at 10:46 PM / IP Logged
Can someone please post a 2003 Dodge Sprinter alarm/remote start wiring diagram?  Thanks.
raydawg357
Silver - Posts: 769
Posted: May 19, 2004 at 3:18 PM / IP Logged
12volts
red (100A)
ignition harness
StarterBLACK / YELLOW + ignition harness
Second StarterN/A
Ignitionblack + ignition harness
Second IgnitionBLACK/ red + ignition harness
Third IgnitionN/A
Accessorygray/dk. green + ignition harness
Second AccessoryN/A
Keysenseblue/black - ignition harness
Power LockWHITE/ yellow - sw on dash or CTM, pink plug, pin 7
Power Unlocksame wire as power lock
Lock Motorblue/red 5wiDKP or CTM, pink plug, pin 2
Unlock MotorBLACK/ red 5wiDKP or CTM, pink plug, pin 3
Parking Lights+gray/black (L), gray/red (R) + fuse box, blk 15 pin plug, pin 4 & 6
Parking Lights-N/A
Hazardsdk. GREEN/ YELLOW - SKREEM, pin 10
Turn Signal(L)BLACK/ white + fuse box, blk 15 pin plug, pin 8
Turn Signal(R)BLACK/ dk. green + fuse box, blk 15 pin plug, pin 5
Reverse LightWHITE/ red + blk 12 pin plug under cluster, pin 1
Door TriggerBROWN / white - driver kick, door harness
Dome Supervisionsame as door trigger wire
Trunk/Hatch PinBROWN / white - rear pin switch or interior light
Hood PinBLACK/ blue pin switch or SSM, brn plug, pin 14
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armred - DKP or SSM, brown plug, pin 21
Factory Alarm Disarmblack - DKP or SSM, brown plug, pin 20
Disarm No Unlocksee factory alarm disarm
Tachometerdk. GREEN/ YELLOW ac data link connector, pin 3
Wait to start
Brake WireBLACK/ red + brake pedal switch
Parking BrakeBROWN / black - parking brake switch
Horn TriggerBLACK / YELLOW - steering column
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Immobilizer Bypass Module
2003 Dodge Sprinter Alarm/Remote Start Wiring -- posted image.
MAKE : DODGE | MODEL : SPRINTER | YEAR : 2004
Do it right the first time
Buriy
Member - Posts: 9
Posted: May 19, 2004 at 5:01 PM / IP Logged
thank you very much!!!!!!
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
