sterio wiring diagram/colors
edenp
Posted: September 09, 2002 at 7:16 PM / IP Logged
Help I have a1981 mercury cougar that has been turned into a sleeper but somebody stole the original radio out of it , go figure, now i can't find a wireing diagram to give me the color codes so that I can put in an aftermarket sterio  Thanks
rmn6
Member - Posts: 16
Posted: September 13, 2002 at 2:08 AM / IP Logged
I don't know for sure but this might work check if you have this wire combination and put a meter on the wires carrying current to be sure:
Constant 12V+               Light Green
Switched 12V+               Yellow/Black
Ground                      Chassis
Illumination               Blue/Red
Dimmer                      n/a
Antenna Trigger             ORANGE / Blue
Left Front (+)              Green
Left Front (-)              BLACK/ White
Right Front (+)             WHITE/ Red
Right Front (-)             BLACK/ White
Left Rear (+)               Pink/Red
Left Rear (-)               Pink/Blue
Right Rear (+)              Pink/Blue
Right Rear (-)              GREEN/ Red
edenp
Posted: September 13, 2002 at 4:14 AM / IP Logged
Thanks rmn6 will give it a shot, even trying to find the manual or a chiltons has been next to impossible E
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
