05 Chevrolet Astro Van Alarm/Remote Start Wiring
mxxmikexx
Silver - Posts: 796
Posted: September 28, 2004 at 3:13 PM / IP Logged
is the wiring on the 05 chevy astro van the same as the 04'?
my dei info only shows 04, and says 4 seperate door trigger wires above the climate control module?
mo12v
Posted: September 28, 2004 at 3:18 PM / IP Logged
Same as I see it:
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITE (-)AT INTERIOR LIGHT
Trunk Pin SwitchSAME AS ABOVE
Parking LampBROWN (+)HEADLIGHT SWITCH
Power LockLT BLUE (+)DRIVER KICK PANEL
Power UnlockWHITEDRIVER KICK PANEL
Positive Pulse Door Lock
Accessories
Window UpD\ DK BLUE P\ LT BLUE AT MASTER SWITCH IN DRIVER DOOR
Window DownF/ BROWN F/ TAN *
Ign Key WarnLIGHT GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleasePURPLE (+)AT LIFT GLASS RELEASE SWITCH
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE (+)HEADLIGHT SWITCH
OEM Alarm ArmNO OEM ALARM PRESENT
OEM Alarm DisarmIN SCHEMATICS
* Circuit Type: Reversal Rest At Ground
Remote Start
Tach SignalWHITE/ BLACKAT ANY COIL
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNON GROUNDING TYPE
Brake LightWHITE (+)AT SWITCH ABOVE PEDAL
Reverse LightLT GREEN (+)AT LAMPS OR ON TRANSMISSION
Rear Window Defrost
General Motors Passlock ll
MO
nava94
Silver - Posts: 296
Posted: September 28, 2004 at 9:32 PM / IP Logged
the schematics for the 05 are the same as the 04. all your wires are at the bcm behind the radio, door triggers you have to diode isolate all four wires also at the bcm.
Jweb
Member - Posts: 49
Posted: October 01, 2004 at 1:01 PM / IP Logged
Would this go back to a 02 Astro also?  Thanks,  Joe
mo12v
Posted: October 01, 2004 at 1:16 PM / IP Logged
Shows 2003 to 2005
Here is 2002:
Constant 12 voltsRED (2)IGNITION SWITCH HARNESS
Dome LightBLUE (DR)DIODE ISOLATION NEEDED AT BCM *
Trunk Pin SwitchSAME AS ABOVECOMMON WITH DOORS
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockBLUEDRIVER KICK PANEL
* All 4 Doors Are Wired Independently And Are Found At The BCM Behind The Radio.Orange (Passenger Door),Blue (Driver's Door).Pink (Rear Door) Yellow(Sliding Door).Diode Isolation Needed Cathode(Band) Side Of Diode Faces OEM Wires.        Positive Pulse Door Lock
Accessories
Window UpD\ D BLUE P\ L BLUE/WHITE @ MAIN SWITCH
Window DownR/ BROWN S/ TAN
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleasePURPLE (+)AT SWITCH OR IN DRIVER'S KICK PANEL *
HeadlightsWHITE (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmLT.GREEN(-)IN DRIVER'S KICK PANEL
* Alt. Rear Hatch Release is LT. BLUE Wire (-) At BCM Located Above Radio, Behind Center Of Dash        Reversal Rest At Ground Window Circuit
Remote Start
Tach SignalWHITEAT IGNITION COIL
Ignition #2WHITEIGNITION WITCH HARNESS
Neutral SafetyNOT GROUNDING TYPEOEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT STEERING COLUMN HARNESS
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
 G.M. Passlock II Diagram.
MO
Jweb
Member - Posts: 49
Posted: October 01, 2004 at 3:22 PM / IP Logged
Thank you very much for taking the time to send this...Joe
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
