2001 Malibu Keyless/Remote Start Wiring
srisner
Member - Posts: 11
Posted: November 20, 2004 at 6:42 PM / IP Logged
Anyone now how to isolate wires for a keylss entry system and remote start.
I Already have a wiring diagram from the kit manufacturer, but this is not very helpful when there are numerous duplicate wires making my task difficult.
Worse yet there is no Chiltons/Haynes manual on the 2001 Malibu yet. Only 2000 and the wiring between these years is very different.
rudbwoy69camaro
Silver - Posts: 350
Posted: November 27, 2004 at 4:13 PM / IP Logged
Are you trying to do this blind? without a DMM? You'll need a DMM.
2001 Chevrolet Malibu
ItemWire ColorPolarityWire Location
12Vred+ignition harness *1
STARTERyellow+ignition harness *1
IGNITIONpink+ignition harness *1
ACCESSORYorange+ignition harness *1
SECOND ACCESSORYdk. green+ignition harness *1
TACHOMETERPURPLE / whiteignition coil or ECM *5
POWER LOCKwhite-drivers kick panel in
POWER UNLOCKsame wire*2a black plug
PARKING LIGHTS +brownpassenger kick or column
PARKING LIGHTS -
DOOR TRIGGER*4-*4
HEADLIGHTSdk. blue & pink*3steering column
WIPERSdk. grn & purple+steering column
LF WINDOW UP/DNdk. blue - grayAdrivers door switch
RF WINDOW UP/DNlt. blue - tanAdrivers door switch or kick
LR WINDOW UP/DNdk. green - pur/whtAdrivers door switch or kick
RR WINDOW UP/DNlt. green - purpleAdrivers door switch or kick
TRUNK/HATCH PINORANGE / black-trunk light
HOOD PINnone
TRUNK/HATCH RELEASEBLACK/ white+drivers kick panel
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERblack-steering column
BRAKE WIRElt. blue+at the switch
LOCK MOTORgraydrivers kick panel
UNLOCK MOTORtandrivers kick panel
DISARM DEFEATtanpassenger kick panel
DISARM NO UNLOCKnone
DOME SUPERVISIONwhite-dash light or column
SPEED SENSEdk.GREEN / WHITEECM *5
SUN ROOF OPEN/CLOSEblue - greenAsunroof motor
SUN ROOF LIMIT
LF SPEAKERtan - grayat radio or LF speaker
RF SPEAKERlt. grn - dk. grnat radio or RF speaker
LR SPEAKERbrown - yellowat radio or LR speaker
RR SPEAKERdk. blu - lt. bluat radio or RR speaker
RADIO 12Vorange+at radio
RADIO GROUND
RADIO SWITCHyellow+at radio
RADIO ILLUMINATE
POWER ANTENNAdk. greenat radio
Notes:NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 Remove the radio, without unplugging it, to access the ignition harness. *2 Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse. *3 Requires a high current ground. Use a relay. *4 The lt. GREEN/ black is located in the drivers kick and catches only the drivers door. The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors. Use both door trigger wires and diode isolate each. On the 2 door the lt.blue is in the passenger kick. *5 The ECM is located under the left side of the dash to the left of the column.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
