Found 2006 Chrysler 300 VSS Wire
dkeshish
Copper - Posts: 92
Posted: December 12, 2005 at 5:53 PM / IP Logged
Hello everyone, not sure if anyone needs this info but maybe might help someone from going crazy! First off everyone in the group has been so good with this a week or so back I placed a new topic about my 2006 Chrysler 300 and I couldnt locate the VSS wire for my new pioneer avic n2. With all the help i got the end story is I had to purchase a canpulse 2 from soundgate. It turns out after all of that, the install of the canpulse not working.... I went into the passenger side engine compartment.  in there was a bolt that I undid and found a panel that I pulled out with bunch of connectors. I guess its the PCM BUT WHO KNOWS! in the first connector from the left I peeled back the black tape and found many many wires, Tapped into the green and brown striped wire and IT WORKED!!! No can pulse needed!. I was told that the Chryslers are CANBUS and there for it is digital pulse.... Not the case! once again I own a 2006 chrysler 300. Let me know if anyone needs pictures of where the wire is would be happy to help!
Audio Imagez
Member - Posts: 12
Posted: December 16, 2005 at 12:35 AM / IP Logged
Interesting   Found 2006 Chrysler 300 VSS Wire -- posted image.  . What did you have to do for Install as far as a harness, etc?
Never mistake lack of talent for genius...
Audio Imagez
Member - Posts: 12
Posted: December 19, 2005 at 12:09 AM / IP Logged
I also found out that wire doesn't exist on the C Hemi Model.
