2003 Toyota Corolla Alarm/Remote Start Wiring
apmidura
Posted: December 20, 2002 at 10:11 PM / IP Logged
Hi
I looking for wiring diagrams for 2003 Toyota Corolla. Wires are different  than 2002 Corolla.
Paul
Moderator - Posts: 12,488
Posted: December 20, 2002 at 11:32 PM / IP Logged
|              12V|white & black       |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ white         |+  |ignition harness            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|green *1            |-  |passenger kick panel        |
|     POWER UNLOCK|blue/black *1       |-  |passenger kick panel        |
|       LOCK MOTOR|blue                |   |driver kick, door harness   |
|     UNLOCK MOTOR|red                 |   |driver kick, door harness   |
|    DISARM DEFEAT|red                 |   |driver kick, harness to rear|
| PARKING LIGHTS +|green               |   |driver kick panel           |
| PARKING LIGHTS -|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|RED / yellow          |-  |driver kick panel           |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|RED / white           |-  |light in trunk              |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|*2                  |   |ignition coils              |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |-  |steering column             |
Notes:
*1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door.  *2 Go to any one of the ignition coils under the black motor cover and use RED / blue, YELLOW /GREEN, gray, or white.
Chris Luongo
Platinum - Posts: 3,746
Posted: December 21, 2002 at 11:20 AM / IP Logged
I have some additional tricks that can make this easier....what are you installing?
Posted: December 21, 2002 at 11:40 AM / IP Logged
Hey Chris...what are they for RS & alarm ?
apmidura
Posted: December 21, 2002 at 1:52 PM / IP Logged
Hi Chis !
I want install alarm, remote start and keyless entry with Carbine Start2 - Plus. What triks You now?
Please and Thank You.
Paul
Chris Luongo
Posted: December 21, 2002 at 8:56 PM / IP Logged
Firstly, http://www.carsound.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=3;t=000870 here's a writeup I did when these cars first came out, including pictures too.  Now that I've done more, I have a few things to add.
Tachometer:  Remove the one black plastic "screw" from the instrument cluster trim, and then remove the "insert" that the "screw" was in, and then remove the black frame around the cluster.  You'll see a plug at the top of the cluster, with the wires going upward.  Tach is the black wire that's all the way to the left.
TACH NOTE:  Now that winter's here, I've had a few Camrys (but not Corollas) come back that won't successfully remote start when cold.  The engine hits 2200 RPM when first started during the cold, and this triggers the over-rev protection sometimes.  Just make sure your units overrev protection doesn't kick in too early.  If it does, hold the gas just a tiny bit with your foot, and then reprogram tach at the same time.
DOOR TRIGGER NOTES:  On all models, the RED / yellow in the driver's running board beats the delay, and accepts domelight supervision.  The RED / white at the cluster, just to the right of the tach wire, beats the delay and accepts domelight supervision.  The RED / white at the dash dimmer switch IS affected by the delay, and accepts domelight supervision.  (But, only the upscale LE has factory domelight delay--the stripper models don't.)
DOMELIGHT SUPERVISION NOTES:  Notice that the dash dimmer includes a position that disables the domelight altogether.  You can choose to do your domelight supervision either before or after this switch.  The RED / black from the switch will supervise the domelight ALL the time, whether your customer wants it or not.  If you use any of the three door trigger locations mentioned above, your customer can still 100% disable all domelight activity by moving this switch to "off."
All of the domelight wires mentioned are high-current; you'll have to use a relay to power them.  I even found the wire coming from just the driver's doorpin switch, but this is high-current too.
The Corolla LE (the one with woodgrain) has factory domelight supervision, which comes on when the correct unlock wire is energized.  However, it isn't going to come on when the engine is running under remote start, so you may want to add your own aftermarket supervision anyway.
PARKING AND BRAKE WIRES:  The + parking light wire (green) can be found at the dash dimmer switch, or in the driver's running board.  The GREEN / WHITE brake wire is in the running board too.
 If doing remote start, or alarm/remote start combo, I think it makes sense to bundle your door trigger/park/brake wires together, and run them all to the driver's running board for a simple install.  On the other hand, if you're doing alarm-only on a stripper model, bundle the door trigger/parklamp wires together, and run them both to the dimmer switch and attach there.
REMOTE START NOTE:  The BLACK / YELLOW second accessory wire powers up the climate controls.  The blue/red accessory wire does the radio, and is not necessary for remote start.  Also, the white constant wire is tiny---I always tie all my constant wires into the car's big black constant wire.
DOOR LOCK NOTES:  The green wire in either kick panel, which tests off the door key cylinder, will lock the doors.  If you want two-step unlocking, use the blue / YELLOW in the driver's kick.  If you want single-step unlocking, look for the blue/black in the passenger's kick, although I've never had to.
apmidura
Posted: December 21, 2002 at 9:45 PM / IP Logged
Hey Chris !!!
You can write books about installing. Instructions and pictures are the best. I'm sorry. My english is not very well.2003 Toyota Corolla Alarm/Remote Start Wiring -- posted image. I try install tommorow.
What about trunk release wire? Positive or negative? What color and where?
Thank You
Paul
84celica
Member - Posts: 43
Posted: December 21, 2002 at 10:11 PM / IP Logged
Chris, You're more than welcome to do that for the 2001-2002 Corolla's too if you don't mind... :D You really should think about writing tech books for the install field as your information and the details are quite excellent.
I'll be installing an Alpine alarm in my 2001 Corolla and could use all the help I can get.
apmidura
Posted: December 21, 2002 at 10:39 PM / IP Logged
Jeff, older model Toyota's then 2003 are very simple to install alarm, remote start, keyless entry, etc. It's take me 1 hour. It's easy. What kind of Alpine You put to Your car?  If You have any questions, go ahead.
Paul
apmidura
Posted: December 28, 2002 at 10:11 PM / IP Logged
Hey
It's done. The alarm, remote starter works very good. I install Carbine Start2-Plus. I recomend to put in. Horn trigger is not GREEN / WHITE at steering column. I can't find this wire.
For open trunk I put motor with relay to release hatch.
Thanks  for Chris and Jeff.
Paul
Page of 4
Saturday, November 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
