2002 Jaguar X-type
*theone*
Copper - Posts: 68
Posted: November 03, 2006 at 1:20 AM / IP Logged
anyone have the astroachart or any wiring info on 2002 Jaguar X-Type.
spookiestylez
Silver - Posts: 531
Posted: November 03, 2006 at 2:44 AM / IP Logged
12volts      red (30A)       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter      N/A
Ignition      GREEN/ orange       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      GREEN / WHITE       +       ignition harness
Second Accessory      N/A
Keysense      black       +       ignition harness
Power Lock      green and orange       -       GECM, gray plug, pins 16 and 19
Notes: These wires will meter while turning the key in the driver door key cylinder. The orange wire is the lock detection wire. This wire will meter ground when the door lock motor is in the lock position. Make sure to diode isolate this wire from the lock wire.
The GECM (General Electronic Control Module) is behind the glove box near the kick panel.
Power Unlock      blue (double pulse)       -       GECM, gray plug, pin 14
Lock Motor      yellow/black       5wi      GECM, green plug, pin 3
Notes: The GECM (General Electronic Control Module) is behind the glove box near the kick panel.
Unlock Motor      WHITE/ green       5wi      GECM, brown plug, pin 5
Parking Lights+      red       +       headlight switch, pin 5
Parking Lights-      N/A
Hazards      BLACK/ orange       -       GECM, white plug, pin 23
Turn Signal(L)      BLACK/ green       -       GECM, white plug, pin 17
Turn Signal(R)      BLACK/ green       -       GECM, white plug, pin 19
Reverse Light      GREEN/ black       +       kick panel, harness to rear
Door Trigger      use dome supervision wire
Dome Supervision      BLACK/ pink       -       GECM, gray plug, pin 3
The door trigger wire must be relay isolated to avoid false alarms.
Trunk/Hatch Pin      brown       -       GECM, gray plug, pin 22
Hood Pin      black       -       GECM, blue plug, pin 21
Trunk/Hatch Release      blue       -       GECM, brown plug, pin 16
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock
Tachometer      GREEN/ stripe       ac       any ignition coil
Wait to start      N/A
Brake Wire      GREEN / WHITE       +       brake pedal switch
Parking Brake      black       -       parking brake switch
Horn Trigger      black       -       GECM, brown plug, pin 14
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
rtfm
