96 lexus door lock wiring
shel-tek
Posted: February 05, 2003 at 10:12 AM / IP Logged
need help locating door locks wiring for 96 lexus Ls400
Bnluis
Silver - Posts: 578
Posted: February 05, 2003 at 1:32 PM / IP Logged
  Try these location and test your wires
      POWER LOCK|GREEN/ red           |-  |at ECU in pass door         |
|     POWER UNLOCK|GREEN/ black         |-  |at ECU in pass door
    Luis
Sound Waves
Player69
Silver - Posts: 504
Posted: February 05, 2003 at 1:43 PM / IP Logged
You should also be able to find a GREEN/ YELLOW for lock and green for unlock.  These wires will show ground when you lock or unlock the door with the key only.  The wires can be found in the harness coming from the drivers door or behind the right side of the instrument panel. (wireless door lock control ECU unit)
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
