2007 Chrysler PT Cruiser Alarm/Remote Start Wiring
mbaudio06
Copper - Posts: 60
Posted: March 07, 2007 at 12:06 PM / IP Logged
Any news on this year yet? Can someone post a wiring diagram and some tips? That would be great
KarTuneMan
Platinum - Posts: 7,056
Posted: March 07, 2007 at 12:46 PM / IP Logged
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Red Ignition switch harness   +
 IGNITION Pink/white Ignition switch harness   +
 ACCESSORY Violet/brown
 Second IGN is ground through 600-omhs and Second START is ground through 180-ohms. Refer to the supplied diagram for exact wiring instructions.
 STARTER Pink/blue
 STARTER 2 Violet/brown
 TACH SIGNAL Use a fuel injector
 FUEL INJECTOR Opposite from GREEN/ orange At any injector on engine   AC
 LOCK Lt.GREEN/ dk.green In driver's kickpanel   mux
 One wire doorlock system. 1-kohm to ground for lock and 250-ohms to ground for unlock.
 UNLOCK Lt.GREEN/ dk.green In driver's kickpanel   mux
 DOORPIN SEE NOTES
 Tan (driver's door), Tan/red (passenger door), Tan/orange (rear left) and Tan / YELLOW (rear right). All 4 wires are (-) and found on the back of the instrument cluster.
 HOODPIN BROWN / tan At pinswitch under hood   -
 TRUNK PIN Tan/black In driver's kickpanel   -
 TRUNK RELEASE Tan/green In DKP or behind instrument cluster   -
 FACTORY ARM Through OEM remote only
 FACTORY DISARM Through OEM remote only
 BRAKESWITCH GREEN / WHITE At switch above brake pedal   +
 PARKLIGHTS WHITE/ violet Low in driver's kickpanel   +
 HAND BRAKE WHITE/ black At switch on handbrake lever or behing instrument cluster   -
 HORN Dk.GREEN/ violet At steering column
mbaudio06
Copper - Posts: 60
Posted: March 07, 2007 at 3:27 PM / IP Logged
Im not big on relays any suggestions on an interface that does locks and the bypass. Or maybe post a diagram for the 2nd starter and acc relay and the lock relay diagram thanks...
Hymer
Silver - Posts: 695
Posted: March 07, 2007 at 4:15 PM / IP Logged
The XK532 or CHDL7-PK2 from bypasskits.com   does locks disarm mux and sentry key... his is listed as a 06 on their site though... I dont know if they changed anything in the PT for 07
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
KarTuneMan
Posted: March 07, 2007 at 4:36 PM / IP Logged
07 and 06 are the same!
