2007 honda civic, remote start
frysbay25
Posted: June 13, 2007 at 8:17 PM / IP Logged
Remote start for a 2007 Honda Civic Coupe
rudydapimp
Copper - Posts: 390
Posted: June 14, 2007 at 8:31 AM / IP Logged
This is what I could find on Code Alarms website. But as always - test all wires with a DMM
Battery     WHITE     (+)          IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW          (+)     IGNITION SWITCH HARNESS
Ignition 2     BLACK/ RED     (+)     IGNITION SWITCH HARNESS
Accessory 1     WHITE/ RED     (+)     IGNITION SWITCH HARNESS
Starter 1     BLACK/ WHITE     (+)     IGNITION SWITCH HARNESS
Anti-Theft Type     UNIVERSAL IMMOBILIZER
Anti-Theft Descript     THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Neutral Safety     LIGHT GREEN     (-)     AT GEAR SELECTOR SWITCH
Tachometer     BLUE          (AC)     AT PLUG NEAR VEHICLE BATTERY     Speed Sense     BLUE/WHITE     (AC)     AT MODULE TO LEFT OF STEERING COLUMN
Parking Lights     RED / BLACK     (+)     IN HARNESS TO RIGHT OF STEERING COLUMN
Brake Lights     WHITE/ BLUE     (+)     AT SWITCH ABOVE BRAKE PEDAL
Power Unlock     WHITE/ GREEN     (-)     IN GRAY PLUG HIGH IN DRIVERS KICKPANEL
PowerLock     WHITE/ BLUE     (-)     IN GRAY PLUG HIGH IN DRIVERS KICKPANEL
LF Latch     GREEN          (-)     IN HARNESS IN DRIVERS KICKPANEL
RF Latch     LIGHT GREEN/ RED     (-)     IN HARNESS IN DRIVERS KICKPANEL
Trunk Trigger     BLUE/BLACK     (-)     IN HARNESS IN DRIVERS KICKPANEL
