wiring power inverter
knockn4life
Member - Posts: 9
Posted: July 03, 2008 at 9:35 PM / IP Logged
i am in need of help. i want to hard wire a 400 watt power inverter to the battery but im not sure if it will kill the battery. i have heard that even when its switched off it still draws power and will kill the battery. Is this a myth or true? what other options do i have?
2001 dakota r/t 1 15"RF HX2
1 1000BD power amp 1 1 farad cap 4 channel amp
davngr
Copper - Posts: 109
Posted: July 04, 2008 at 8:05 AM / IP Logged
some inverters can still place a load on the battery even when switched off(led's and crap)  you can solve the problem by adding a seperate switch for just the power source of the inverter.  so when you switch that power off the inverter is isolated completely from your battery.
life is a comedy to think, a tragedy to feel
Platinum - Posts: 13,726
Posted: July 04, 2008 at 3:18 PM / IP Logged
How much current does the inverter pull?
