ipod connection on mmcs unit
n0c7
Member - Posts: 12
Posted: February 09, 2009 at 12:59 AM / IP Logged
I have a 2008 Mitsubishi Outlander XLS which has a MMCS(Mitsubishi Multimedia Communications System) head unit which is essentially a GPS/Satellite/DVD/etc all-in-one double DIN factory head unit.
On the back of it there is a S-Video looking connector. Rumor has it that you can use an iPod cable on it to control your iPod through the interface. The two cables that supposedly work with this are:
Factory Mitsubishi P/N: MZ608561 (aprox $250-300)
Kenwood KCA-iP500 iPod® Control (aprox $100)
They both have a bit of a hefty price tag on them so I'm looking to find out if anyone has tried either of these and whether or not you can actually control the iPod through the head unit before I buy one. The entertainment system does have an RCA input but this provides mediocre sound with very low volume, no charging, and no control. Looking to integrate the iPod, if this in fact is the solution....
airhed692005
Copper - Posts: 72
Posted: February 15, 2009 at 12:05 AM / IP Logged
I just looked at the KCA-iP500 on ebay $15 or more. Get it there if you thank it might work on it. Don't spend the $100
Ronald Bailey Owner/ Installer of VIBRATION CUSTUM SOUNDS. CUSTOM BOX DESIGNER AND BUILDER
TID-896 7" screen,Amp-BX1206d
4/0power/ground cables
4-12 mofos 12ft3 box tuned 40hz DB:163.1
