how to connect lcd headrest to end unit
limit
Member - Posts: 24
Posted: February 08, 2010 at 10:38 PM / IP Logged
I have installed 2 lcd monitors in my headreset and I am not sure how to connect them to the deck, the deck has a componet female connector out and the both lcd monitors from the headrest also have a female componet connector. How would I connect both the lcd monitors to my end unit?
Thanks in advance
ceasar326
Copper - Posts: 239
Posted: February 09, 2010 at 12:00 AM / IP Logged
Depending on the inputs or outputs of your dvd headunit and heatrest, you will need an rca splitter to connect both LCD's to your dvd headunit. Also depending on the brand LCD's, most LCD's will require a video-amp. Thats for a better clear picture. If your LCD's are equipt with audio input i would also connect both togethere with RCA splitters.
Hope this help.
bholt18
Posted: May 01, 2010 at 5:22 PM / IP Logged
What if the monitor has only sv connector
97 Yukon lvmshvd
Tuesday, January 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
