i need schematics for veba 7 dvd player
groovejet
Member - Posts: 6
Posted: February 09, 2011 at 11:48 PM / IP Logged
Ive got a few problems with my Veba 7" tft dvd monitor.
Cant find model no. but i know the unit is discontinued.
Its the roof mounted model.
I have the serial no- 0422380566
I need wiring diagrams for the units circuit itself/or simply just the diagram for the associated wire connections .
Also has anyone got info on wiring up from start to fin, i.e from the power supply to the wiring of all associated controls?
thankyou
Platinum - Posts: 13,725
Posted: February 10, 2011 at 12:48 PM / IP Logged
How many wires are there?  What colors are they?  Are there any RCA connectors?
groovejet
Member - Posts: 6
Posted: February 10, 2011 at 8:45 PM / IP Logged
i need schematics for veba 7 dvd player -- posted image.
Hope these pics help.
As you can see, some connections have been snipped on pcb-
From left to right-
Bk-Grd
R-R1
Wh-L1
Bk-Grd
Y-V1
Wh- L Out
R- R Out
Bk-coo
Y-V Out
Bk-Grd (Missing wire? Connection broke?
The black Female jacks in image have never been previously used.
The 4 wires Wh, Y, R, Bk were connected into chock block and pushed out of sight in roof panel.
I appreciate your interest, cheersi need schematics for veba 7 dvd player -- posted image.
groovejet
Member - Posts: 6
Posted: February 10, 2011 at 8:50 PM / IP Logged
Can you see the images? Because i cant?
I'll upload them again if you cant see them, ok
groovejet
Member - Posts: 6
Posted: February 10, 2011 at 9:08 PM / IP Logged
The images not showing! Is it something to do with File Extensions?
What do i do?
groovejet
Member - Posts: 6
Posted: February 28, 2011 at 12:12 AM / IP Logged
been 18 days since last post!!! not much help out there, is there???
Posted: February 28, 2011 at 10:25 PM / IP Logged
Last time I checked, I could not see the images.  I guess I should have read what you typed.   R-R1 = right channel audio.  WH-L1 = left channel audio  Yellow = Video
Same wire colors for the outputs as well.  Red = Right, White = left  Yellow = Video.
All wires labeled GND are common with each other and ground for the device.
groovejet
Member - Posts: 6
Posted: March 03, 2011 at 4:05 PM / IP Logged
Thankyou "im a idiot"
