06 f250 factory b/u camera to 4400bh
robd007
Member - Posts: 25
Posted: November 15, 2012 at 9:47 PM / IP Logged
Is there a way to connect the factory backup camera to a pioneer avh-p4400bh?
Thanks in advance
Platinum - Posts: 13,725
Posted: November 15, 2012 at 11:07 PM / IP Logged
There will be either 3 of 4 wires coming from the factory camera. One will be 12 volts when the vehicle is placed in reverse. Another will be video signal. There will be either 1 or 2 grounds. If 2, they are common and it does not matter which you use for power ground or video ground. Cut this cable and splice accordingly.
