Headrest Flush Look
Legrones
Copper - Posts: 75
Posted: May 13, 2003 at 11:02 PM / IP Logged
 Hello could someone tell me how do I go by getting the nice smooth flush look in my headrest of my surburban I want the tv's so where it look like it is completely in the headrest and the shroud is not showing or is it some type of housing case i can order or buy from somewhere.
Dale / Cory
brianh
Silver - Posts: 518
Posted: May 18, 2003 at 8:09 PM / IP Logged
The way I do it is to not use the shroud at all. pop the screen out of the shroud and use it as your templete. Then to affix to the headrest just use some velcro on the foam. I have never had a problem doing it this way.   Brian
Legrones
Copper - Posts: 75
Posted: May 19, 2003 at 8:35 AM / IP Logged
 I also heard that people use mdf wood and place it inside the headrest and mount it in like that to
Dale / Cory
Discman
Member - Posts: 30
Posted: May 25, 2003 at 8:31 PM / IP Logged
You could also try mounting the shroud flush in the hrest and then flap the material over the shroud and then push in the screen.
Good Luck
Discman
Member - Posts: 30
Posted: May 25, 2003 at 8:35 PM / IP Logged
If you don't have the screens yet you should look at visualogic 7" screens that are pre-mounted in a replacement headrest for you. They look great and take 10 minutes to install. They are a little pricey but they save a lot of time and labor.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
