cva-1003 - what is going on here?
platnum525
Posted: May 24, 2003 at 6:25 PM / IP Logged
i have the cva-1003, i have a dvd player on it, i took it off and put on xbox, and boom black screen only audio, so i thought maybe not enough volts so i run xbox straight into house outlet still nothing, go into house with xbox and perfectly works, so i go and try dreamcast unplugging dvd first and boom same sh*t still doesnt work, the only thing that works is the dvd player this is eating me alive this problem, do you have any idea whats going on here? because i sure as hell dont thanks alot you can email me at platnum525@yahoo.com thanks alot
brianh
Silver - Posts: 518
Posted: June 01, 2003 at 7:46 PM / IP Logged
There should be a parking brake wire on the unit. It is a wire that is to be hooked up to the parking brake wire that goes to ground when the car is stopped. (safety device)Find this wire and hook it straight to ground and you will have a picture. Good luck with it.
Brian
owner/installer
Sight & Sound Car Stereo
djfearny2
Silver - Posts: 810
Posted: June 01, 2003 at 8:25 PM / IP Logged
no this is a alpine peice there is two wires., and now you cant just hook it up to ground it has to be hooked to the brake wire and to either the parking brake or a switch., that flips it between ground and nothing.
these wires a yellow/blue and yellow black. the yellow blue wire is the possitive side you can either hook thei up to cold side of foot brake of with a momentary wsitch that is fed from a 12 volt source. not ground. and the yellow/black wire either has to be hooked up to the hand brake wire or a toggle swtich with the other end of the toggle switch connected to ground and what you would have to do is with a push button pos switch is push the button hold it and flip the switch three times leaving it in the on postion. and then let go up push button or .. if your connected to foot brake than push brake flip toggle three times leaving it in the on pos and let go of brake .....make sure your video is ok the 1003 only has one video input you have to make sure video is ok. try hooking video straight to the iva it self not through any rca or anything   any more help email me.
Jon
Installer/Help Technician
---coral springs florida---
purplehays
Posted: June 05, 2003 at 12:42 AM / IP Logged
i had a similiar problem with a ps2 the fix to the problem is the video signal. it can be fixed with a composite video adaptor. This part is sold separately. i found mine at circuit city
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
