not valid on my alpine CVA1005
jakemarley
Member - Posts: 7
Posted: June 07, 2003 at 2:34 PM / IP Logged
When I attempt to play a DVD using my DVA5200 I press play on my CVA1005 headunit and the screen says "Not Valid"  Am Imissing something or do I have something hooked up wrong?
Jake
Platinum - Posts: 12,488
Posted: June 07, 2003 at 11:32 PM / IP Logged
Hey Jake, did you go through the parking brake & foot brake sequence to engage the safety bypass for the DVA5200 ??
jakemarley
Member - Posts: 7
Posted: June 08, 2003 at 6:26 AM / IP Logged
Yes I did.  I have video, it just won't start playing.
The Intro for the DVD starts, and gets to the title/menu section where you have to push play.  I push play and "not Valid" appears at the top and the DVD doesn't start.
Jason
Posted: June 08, 2003 at 8:25 AM / IP Logged
Whenever this happens to me on my DVA5200, that means that I tried to press PLAY too soon and the function is disabled until the menu finishes it's course. Also, are you using the long flat remote control from the DVA5200 to play the DVD ?
jakemarley
Member - Posts: 7
Posted: June 08, 2003 at 8:40 AM / IP Logged
No just using the controls on the CVA1005 headunit.
Jake
Posted: June 08, 2003 at 9:02 AM / IP Logged
try using the long flat remote from the DVA package. This will work for you.
jakemarley
Member - Posts: 7
Posted: June 08, 2003 at 9:06 AM / IP Logged
ok I'll try it.  But any other ideas ?  I thought you were supposed to be able to control from the head unit?
Jake
Posted: June 08, 2003 at 9:20 AM / IP Logged
Only certain functions are available to the CVA1005 . Otherwise all the functions are controlled through the DVA remote control.
jakemarley
Member - Posts: 7
Posted: June 08, 2003 at 11:24 AM / IP Logged
thanks Jeff!
