Xbox install project question
Nextreme
Posted: September 19, 2004 at 12:29 AM / IP Logged
Hey there.
I have been thinking of installing my XBox in my car.  I have been doing a lot of research and I was thinking of taking the XBox apart and putting it into a custom console to hide in the car - no prob.  This brought up another idea though - since the car runs 12 -14V DC, and the XBox internally uses 12V and 5V DC, why not replace the XBox power supply with a DC-DC power supply instead of using an inverter?  It would save room and the hassle of the inverter.
Has anyone done this?
Where can I get such a power supply?
Thanks in advance,
Scott
xtremeaudio
Copper - Posts: 174
Posted: September 19, 2004 at 8:00 PM / IP Logged
only way for now you have to use inverter xbox need about 400w to power up
juniorxs
Member - Posts: 26
Posted: September 20, 2004 at 5:15 AM / IP Logged
http://benheck.com/
try this, under videogames forums, it's all about making consoles portable.
Nextreme
Posted: September 20, 2004 at 8:17 AM / IP Logged
juniorxs wrote:
http://benheck.com/
Thanks for the link, looks like a wicked site
dxav
Silver - Posts: 314
Posted: September 20, 2004 at 9:57 AM / IP Logged
Did it with a few PS2 systems, but not an XBOX. Should be the same though. I know the GC is easier, the power inverter is external to the system. I just built a voltage regulator circuit on a PCB and took out the AC power converter from the system. Works great, just check the current draw and you may not be able to use an LDO V reg.
Good luck,
DXAV
