Wiring tv
Rittler2000
Member - Posts: 7
Posted: September 30, 2002 at 1:04 PM / IP Logged
I just wanted to ask if it is better to straight wire a car tv directly to the battery or connect it to the accessory wire. will the tv get to much amps if i wire it to the battery directly? what if i connect a switch in it?
Ben
Ben
the12volt
Administrator - Posts: 3,959
Posted: September 30, 2002 at 1:07 PM / IP Logged
Hi Ben, the TV will pull the same amount of current from either power source whether you use a switch or not. If you do connect it directly to the battery you'll want to use a switch to turn it on and off. If you connect it to an accessory lead, it will turn on and off with the key.
tlbuckingham
Posted: September 30, 2002 at 6:57 PM / IP Logged
I am assuming that the accessory lead is just the wire when turning your vechicle on. Can I just splice into it?
the12volt
Posted: September 30, 2002 at 7:02 PM / IP Logged
Hi Ben, yes, you can splice into the accessory lead in the ignition harness. If you  tell us what year, make, and model vehicle you have, we can tell you exactly which wire you should connect to.
djfearny2
Silver - Posts: 810
Posted: September 30, 2002 at 7:37 PM / IP Logged
your better of splicing in to the acc wire cause bad things usually happen when you run little things like that to the battery let the car alternator do the work not the battery
Jon
Installer/Help Technician
---coral springs florida---
tlbuckingham
Posted: September 30, 2002 at 8:28 PM / IP Logged
Actually i was me that asked that question. I have a 2002 Isuzu Rodeo LS (4x4). By the way where do you get your information from (I usually pick up Haynes manual from pepboys)
djfearny2
Silver - Posts: 810
Posted: September 30, 2002 at 8:31 PM / IP Logged
well most installers get there info from the field and actually doing the installs . haynes books and stuff dont tell you better than experince they are good for torching and stuff.
Jon
djfearny2
Silver - Posts: 810
Posted: September 30, 2002 at 8:32 PM / IP Logged
tlbuckingham.
what info do you need email me if any forther assistance is wanted or needed
Jon
Zezzar
Member - Posts: 18
Posted: October 09, 2002 at 12:26 AM / IP Logged
ok,so please tell me few things:tv size,meke,model
Zezzar
Member - Posts: 18
make,model,sorry
