AVIC-N1 Voice Recognition Problem
eMass
Member - Posts: 8
Posted: October 06, 2004 at 2:08 PM / IP Logged
Just had this unit installed with the optional voice recognition unit. Has anyone else had a problem with the voice control feature where the little voice icon that's supposed to show up on the lower left part of the screen telling you it's possible or not to input voice commands never shows up at any time, in any screen? Also the Auto Voice  Recognition option under Settings is grayed out and is set to off? Does that option turn the voice feature on? If so, why is it grayed out? Is there some other way to turn voice recognition on? Is it possible that the installer ran the wire for the microphone and everything but did not connect it to the headunit therefore the system does not recognize that it should turn the feature on or something?
TIA,
eMass
->eMass
awilliams64
Member - Posts: 40
Posted: October 06, 2004 at 3:54 PM / IP Logged
definitely possible...did you really get the pioneer mic or did they try to use one from something else?? did you also get the remote?? the pioneer comes w/ the remote as well as the mic so check out all of those things
eMass
Member - Posts: 8
Posted: October 06, 2004 at 6:26 PM / IP Logged
No, they used the pioneer mic and remote - I have the packaging and everything.
If anyone has and avic and can easily unplug the mic from the system, can you see if it displays the same symptoms?
Thx.
->eMass
Akhan
Posted: October 20, 2004 at 9:52 AM / IP Logged
I am facing the exact same problem, have you ever got fixed?
Abby
honda4x4nut
Member - Posts: 30
Posted: October 20, 2004 at 2:26 PM / IP Logged
I had the N1 you will need to be sure the tiny plug that goes into the brain from the mic has not come out very easy to pull out. This happened to me. when they take the vehicle apart to fix this get them to set up the system to recognize it before every thing is back together alot easier than going back and forth, enjoy the CD-VC1 well worth it imo!
Black 04 Cadillac Escalade EXT- 13 INCH suspension LIFT,37"nitto mud grapplers,22"MC2 Cadillac wheels, 05 touch screen Nav system, backup cam, Headrest and visor monitors and video input on nav system
awilliams64
Member - Posts: 40
Posted: October 20, 2004 at 6:48 PM / IP Logged
also check to make sure it is in the mic input not the wired remote plug, it will fit in either one so this may be the problem
jeremyjerm
Member - Posts: 46
Posted: October 23, 2004 at 3:05 PM / IP Logged
reset the avic and leave the mic plugged in. ive had this problem and ive fixed it too, but it was a loooong time ago. sorry i cant be more helpfull
ODLeon
Copper - Posts: 57
Posted: October 25, 2004 at 1:46 AM / IP Logged
like they said, make sure to plug it in where it says MIC. take out the main harness from the back, plug in mic, plug harness back in. I had the exact same prob, then i read the directionsAVIC-N1 Voice Recognition Problem -- posted image.
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
