2004 Pathfinder SE Wiring
Jdawg965
Posted: December 23, 2004 at 11:37 PM / IP Logged
i am installing a double din dvd,cd,cdr,cdr etc... player in a 2004 nissan pathfinder se with a built in amp. i wired the unit up and connected it to the car and i got no sound?? i rewired it and hooked up the "amp turn on wire" to the 12volt power supply and this time when the unit was turned on i got a click from the stock amp and a pop from the speakers but still no sound?? so i took the unit into my house and hooked up to a spare car battery and a speaker i had and i got sound fine through the speaker? im not sure if there is something i have to do to bypass the amp or if i need a different kind of harness?? please help if you have any ideas!!! thanks
-Jason
auex
Platinum - Posts: 5,041
Posted: December 24, 2004 at 12:05 PM / IP Logged
Is it bose? If it is then you will be rewiring it.
Here is DEI's notes and wiring for the audio.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Jdawg965
Posted: December 24, 2004 at 1:30 PM / IP Logged
there was already a alpine tv connected my buddy just unhooked the harness from the alpine and hooked the stock unit back up? that is what i dont get?? there was already a tv in there unless there is a different harness i need?? thanks for the help
-Jason
auex
Posted: December 24, 2004 at 2:00 PM / IP Logged
Usually a radio cannot wire directly to bose amplifiers.
Some manufacturers make an adapter harness to go from aftermarket to bose.
If you can, ask your buddy how he got it to work and if he had to get an adapter harness.
Jdawg965
Posted: December 26, 2004 at 12:34 AM / IP Logged
he had the unit installed by a pro, and he said when he went to put everything back to stock he didnt realize if the harness was different.. do you know where i could find a harness adapter and also someone said something about a "trigger switch"?? get back to me thanks
-Jason
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
