cva 1005 problem
thinmyster
Member - Posts: 9
Posted: February 25, 2005 at 12:16 AM / IP Logged
hey i was installing my cva 1005 and just playing around with it when either the yellow/black or yellow/blue wire touched something. now my deck wont turn on or anything??? im a total newbie at this and not sure what just happened???
thanks for the help
those two wire you play around with to bypass the security features
Asmodeus
Silver - Posts: 393
Posted: February 25, 2005 at 9:51 AM / IP Logged
If you are getting no power to the unit at all....
First check the fuses in the cars fuse box....Depending on the car there may also be a fuse box under the hood....
Then if thats not it check your connections...Make sure one or more have not pulled loose...
Then check the fuse on the rear of the HU itself....
If thats not it...Ummmm....Get a chicken and a sharp knife...Kill the chicken pull out the feathers...lay them around the HU on the ground and sprinkle the chicken blood onto the unit and pray.....
But probally one of the first 3 will be your problem...
cva 1005 problem -- posted image.
Making the World A Louder Place
thinmyster
Member - Posts: 9
Posted: February 25, 2005 at 1:06 PM / IP Logged
haha thanks i checked the fuse on the back of the unit but nothing else ill check tonight thanks for the responce by the way its a 91 mr2 dont know if that makes a diff
5615669
Posted: March 07, 2005 at 5:35 PM / IP Logged
I have s similar problem.  The unit was playing this morning and it was closed but it woudlnt respond to any commands via the remote or the face.  I checked the fuse on the deck and its good. I have done a reset and unplugged the brain. Is my cva dead or am I missing something? It has no lights no nothing. When I unplugged the brain the changer cycled through the cd's and I imagine it would play but its most likley in pause. Thank for ANY suggestions!!!!
stavy customs1
Copper - Posts: 63
Posted: March 08, 2005 at 12:55 AM / IP Logged
get rid of the 1005 i had that unit and it was garbage i had so many problems with it.
Best Buy Installer
