AVH-5700 and PS2
jediraverz
Posted: July 24, 2005 at 10:52 PM / IP Logged
OK so I have a 2005 Subaru WRX wagon and I installed the AVH-5700 a Vector 400 watt power inverter and my PS2.
My question is when I turn on the inverter and have the Monitor set to Video everything is ok, when I plug in the PS2 even if its not on I get Audio and Video distortion , when I turn the PS2 on I get Very bad audio and white lines on the monitor. I have tried differnt cables for power from PS2 to inverter and Different cables from PS2 to monitor , also tried 2 other inverters. Could it be the Inverters that im using might be missing some kind of filter or something. I work in a Bay and when we do mobile video we usually use Monster Power inverters but we no longer carry them.
I also tried a Game Cube and it did the same thing. After all this I thought my car could have very poor grounds so I regrounded with 4Gauge wire and ground to a couple different points in the Engine bay. Any Advice will help. thanks
Moderator - Posts: 12,488
Posted: July 25, 2005 at 9:25 AM / IP Logged
The only other thing that has not changed in your scenarios is the Pioneer unit. Have you tried installing other input devices like maybe a DVD player to see if the problem persists without the use of an inverter ? If the problem is still there with a DVD player, then I would suspect the Pioneer system.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
