VSS wire in 1996 GMC Jimmy
turbovr6
Member - Posts: 14
Posted: November 23, 2005 at 6:22 PM / IP Logged
Can someone tell me where this wire is, and if it is analog or digital?  I found a diagram on this site that points to the abs module. My nav. install manual says DO NOT tap into the abs harness.
Jay
extreme1
Silver - Posts: 1,070
Posted: November 23, 2005 at 8:06 PM / IP Logged
GREEN / WHITE @ the ECM under the hood, or at the instrument cluster. Or at the radio if the factory had volume sensitive volume
Shaughn Murley
Visions Electronics
Red Deer, Alberta
turbovr6
Member - Posts: 14
Posted: November 23, 2005 at 8:50 PM / IP Logged
Thanks for that quick reply.   I was reading that there should be a VSS wire in my over head console. Would you know which wire that is? It would be much easier for me to route a wire up there.
extreme1
Posted: November 23, 2005 at 9:58 PM / IP Logged
same color, I don't know why there'd be one up there though.
Instrument cluster seems the best bet.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
turbovr6
Member - Posts: 14
Posted: November 24, 2005 at 11:09 AM / IP Logged
Thanks again. over on the s10 forums the claim is that the temp and or compass use the vss as an update signal
rlith
Member - Posts: 17
Posted: November 27, 2005 at 1:52 PM / IP Logged
For the temp...
Yo
