2001 gmc speed signal wire?
gump666
Member - Posts: 17
Posted: July 23, 2006 at 5:13 PM / IP Logged
i am installing an avic-n3 in my 2001 gmc sierra and wanted to know were to find the " speed signal wire "??
josh1979
Silver - Posts: 320
Posted: July 23, 2006 at 8:06 PM / IP Logged
Speed Sense dk. GREEN / WHITE    ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
bring back the rotary phone so i dont have to press 1 to proceed in english
sparkie
Platinum - Posts: 2,061
Posted: July 23, 2006 at 8:55 PM / IP Logged
Use the GREEN / WHITE at the instrument cluster.
sparky
gump666
Member - Posts: 17
Posted: July 30, 2006 at 3:56 PM / IP Logged
i found that there are 2 GREEN / WHITE wires behind the gauge cluster, but i traced it down to the right one.. i hope..
sparkie
Posted: July 30, 2006 at 9:11 PM / IP Logged
The correct one is in the third cavity next to the white wire.
sparky
extreme1
Silver - Posts: 1,070
Posted: July 31, 2006 at 1:27 PM / IP Logged
there also may be one in the radio harness if your deck has SVC
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
