Connecting Aux Monitor to CVA-1005
tmack
Posted: February 11, 2003 at 1:21 PM / IP Logged
Is there a special way to connect an Alpine TME-M750 to a CVA-1005? Do I just connect the power harness wires from the monitor brain, to the same ones on the CVA-1005 brain? Then just connect the rca's? Whatever insight would be helpful.
Than
auex
Platinum - Posts: 5,041
Posted: February 11, 2003 at 3:43 PM / IP Logged
There really is nothing special to connect another monitor to a cva.  All you should have to do is wire the power up, however you want it probably swiched of some sort, and ground it.  Then connect the video output from the cva's control box to the input of the monitor.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Platinum - Posts: 12,488
Posted: February 11, 2003 at 5:16 PM / IP Logged
If you hook up the TME to the CVA you will only be able to play what is in the video source of the CVA on the TME. If you want it to play a different source on both, you will need a switch box.
