05 lincoln aviator rear dvd
aviator2005
Member - Posts: 12
Posted: November 29, 2007 at 9:38 PM / IP Logged
Hey guys        Has anyone here replaced the factory head unit in a 05 aviator and retained the factory overhead dvd?i called metra and asked them about their part # 70-5520av but the tech said it only works in 30% of ford vehicles but he could not say for sure which ones! Has anyone done this sucessfully without keeping the stock radio powered up in the vehicle?
crewwzin
Member - Posts: 25
Posted: December 17, 2007 at 2:14 PM / IP Logged
I have a customer who is wanting to do this exact thing and I would also like an answer to this question.
I'd rather be in the boat with a drink on the rocks, than in the drink with a boat on the rocks!
Ween
Platinum - Posts: 1,368
Posted: December 20, 2007 at 2:03 PM / IP Logged
hi,
connect the light GREEN/ black at the radio to either accessory or amplifier turn-on.  this will power up the overhead.
now to get audio into the headunit, locate the red, white, orange and yellow wires in the same connector that the above light GREEN/ black wire is in.  red...left chnnl +, white...left chnnl -, orange...right chnnl +, yellow...right chnnl-.
connect the respective channel +'s to the center leads of rca connects, channel -'s to the shields.  you may need a ground loop isolater if you have noise/whine problems
mark
