subwoofer vs ib subwoofer
meh66
Copper - Posts: 266
Posted: October 09, 2008 at 8:02 AM / IP Logged
I wanted to know how could I look at a woofer and be able to know if it is an IB woofer or one that should be used in a box? Does IB (Infinite Baffle) mean the same thing as free air?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
megaman
Copper - Posts: 385
Posted: October 09, 2008 at 9:07 AM / IP Logged
You can't just look at a sub and determine if it's IB or not.  It's gonna look exactly like it's boxed counterpart.  The spec sheet will tell you if it's IB or not.
Yes, Infinity Baffle is the same as Free Air.
meh66
Copper - Posts: 266
Posted: October 09, 2008 at 12:37 PM / IP Logged
Thanks Megaman.....here are the specs of the woofer. Dayton said it could be used in a free-air because the QTS is high. In my reading of these terms..I would think that the VAS would be better reference...but I am new at understanding about speaker measurements.
SD215-88 8" DVC Shielded Series Subwoofer Specifications
  • Power Handling: 80 watts RMS/120 watts max
  • VCdia: 1.5"
  • Le: 1.2 mH
  • Impedance: 8 ohms per coil
  • Re: 3.00 ohms
  • Frequency range: 30-2,000 Hz
  • Fs: 28 Hz
  • SPL: 89.0 dB 2.83V/1m
  • Vas: 1.40 cu. ft.
  • Qms: 3.40
  • Qes: .47
  • Qts: .41
  • Xmax: 6 mm
  • Dimensions:
    Overall Diameter: 8-1/2"
    Cutout Diameter: 7-1/8"
    Mounting Depth: 4-1/4"
MEH66
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
