FORD Pick-up FS.
sabioundus
Member - Posts: 28
Posted: March 22, 2002 at 5:56 PM / IP Logged
Hello Guys,
I just want to ask about a Remote Starter for a Ford Pick up 2002 (Mexican). Is there any difference between Mexican and US cars from the same year?
It has factory security system  and I know it woun't start remotelly if I do not use a By-pass module.  I have done many RS, but no one with factory security. This is the newest car I ever work, all my customers were 94's and older.  Any sugestions on how to install it or what have you done to install a RS for this kind of vehicle. All your comments are very appreciated.
Thanks and Regards.
the12volt
Administrator - Posts: 3,959
Posted: March 23, 2002 at 8:38 AM / IP Logged
Hi saioundus, here's what I have for a 2002 F150:
Battery: Yellow at Ignition Switch Harness
Starter: RED / Light Blue at Ignition Switch Harness
Ignition 1: Dark Blue/Light Green & Blue/Green at Ignition Switch Harness
Ignition 2: Gray / YELLOW at Ignition Switch Harness
Ignition 3: RED / Black at Ignition Switch Harness
Accessory : BLACK/ Light Green at Ignition Switch Harness
Tach: Light GREEN / WHITE at Pin 26 of 104 Pin Connector at PCM
Key Sense : BLACK/ Pink (-) at Steering Column
Neutral Safety : RED / Light Blue (+) at Ignition Switch
Door Trigger: Dark GREEN/ Orange (-) at GEM Module, Pin 9 of 26 Pin Connector
Parking Lights: Brown (+) at Switch
Headlights: RED / Light Green (+) at Switch
Brake (cold side): Light Green at Brake Switch
Horn: Dark Blue (-) at Steering Column
LF Up: WHITE/ Yellow at Driver's Switch
LF Down : WHITE/ Black at Driver's Switch
RF Up : WHITE/ Yellow at Driver's Switch
RF Down : Tan/Light Blue at Driver's Switch
LR Up : Gray/Orange at Driver's Switch
LR Down : Yellow/Light Blue at Driver's Switch
RR Up : Yellow/Black at Driver's Switch
RR Down : RED / Black at Driver's Switch
Sunroof Open: Blue at Switch
Sunroof Close: Violet at Switch
Lock: Pink / YELLOW in Driver's Kick Panel, 5 wire (+) on base models, check polarity
Unlock: Pink/Green in Driver's Kick Panel, 5 wire (+) on base models, check polarity
Driver's Motor Unlock: RED / Orange in Driver's Door Jamb
Driver's Motor Lock: Pink/Black in Driver's Door Jamb
Passenger's Motor Unlock: Pink/Orange at RKE
Keyless Entry Module (RKE) is located high in Driver's Kick Panel
OEM Anti-Theft System: PATS under Driver's Side Dash
Factory Disarm: Dark GREEN/ Purple in Driver's Kick Panel
Two Step Factory: 5 Wire(+) without RKE, 3 Wire(-) with RKE
All wire colors in your vehicle should be the same, but as always, verify each before making any connections.
the12volt
sabioundus
Member - Posts: 28
Posted: March 25, 2002 at 4:42 PM / IP Logged
Thanks for the info. Just few questions:
How to connect the PATS by pass?
What is the Two Step Factory and the RKE?
Is the factory disarm + or - signal?
Regards.
Sabioundus
Platinum - Posts: 12,488
Posted: March 26, 2002 at 1:24 PM / IP Logged
You will need a PATS bypass module and an extra key to introduce the proper resistance to the PATS computer.
  • The RKE is a Remote Keyless Entry
  • The factory disarm is ( - ) input signal
The last time I installed into a 2001 Ford F150 V8 the customer had a RKE system BUT it was not what all the paper's and database wiring diagrams said it was ! IT eneded up being a straight ( - ) grounding system. The stupid thing was that the power unlock was not in the factory keyless entry module ( ??? ) The lock wire was a PINK / YELLOW ( - ) located in the RKE module and the unlock wire was a  PINK/LT.GREEN ( - ) located behind the passenger kick panel in a loom of wires leading to the passenger side door.
The PATS bypas system is easy ... take a relay ( 30/40 amp ) and hook it up like this:
  • 86 - Primary ignition ( BLUE/GREEN )
  • 85 - Ground out when running on remote starter
  • 87 - Key cylinder( wrap a 22 gauge wire around the key cylider column about 8 - 10 times and connect to pin 87 . This wire must be 20 - 24 gauge otherwise it will not introduce the signal into the PATS properly and you will get hit and miss starts.
  • 30 - Spare key with resistor in the black molded top part. You must wrap the the same wire that goesinto pin 87 around this key about 8 - 10 times as well and connect to pin 30.
I hope this is easy to follow and if not let me know and I will put up a picture of this circuit for you later.
sabioundus
Member - Posts: 28
Posted: March 26, 2002 at 9:56 PM / IP Logged
You are always there Jeff.
This is great info and clear. I will be working on this car next Thursday and I will let you the final result.
Thanks and Regards.
Posted: March 27, 2002 at 7:21 AM / IP Logged
Hey not a problem !! FORD Pick-up FS. -- posted image. I figured that I spent about 16 hours trying to find all the problems with the Ford truck, why should you have to !!. Just make sure of all your connections and test for wire verification to ensure that what we are advising is what your vehicle has. Good luck and if you have any more problems, please post and someone will be able to help you out .
JoeVega1516
Posted: May 26, 2002 at 10:47 PM / IP Logged
Hey!
I am going to install a remote start system in a 2002 Ford Expedition will this info
be helpful on my Install?
Are there any special Instructions or things to look out for any help would be greatly appreciated
Joe
Joe Vega
Posted: May 27, 2002 at 4:43 AM / IP Logged
Ford
Expedition
1997-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / L BLUE
IGNITION SWITCH HARNESS **
Ignition  #1:
D BLUE/GREEN
Ignition #2:
RED / BLACK
Ignition  #3:
GRAY / YELLOW
Accessory:
BLACK/ L GREEN
Brake  Light:
L GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE/ PINK
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
D GREEN/ PURPLE (-)
DRIVER KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. ** This Vehicle May Be Equipped With Ford's PATS Anti-Theft System.
Ford
Expedition
1997-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW (2), ORG/YEL &
L GREEN/ PURPLE (2) IGN. SW. HARNESS
Starter  Kill:
RED / L BLUE
Ignition  +12 Volts:
D BLUE/GREEN
Dome  Lights/Superv:
BLACK/ L BLUE (+)
PASSENGER KICK PANEL
OEM Horn:
D BLUE (-)
STEERING COLUMN HARNESS
Power  Lock:
PINK / YELLOW
DRIVER'S KICK PANEL ***
Power  Unlock:
PINK/L GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ L BLUE (+)
Notes:
*** Without OEM Keyless Entry  Reverse Polarity Door Lock , With OEM Keyless - Positive Pulse Door Lock
