can you id this connector?
jeem
Posted: December 06, 2010 at 8:17 PM / IP Logged
Hi all,
I installed a flip down monitor in my Honda Odyssey where the dome light used to be. The monitor includes a 'dome' light that I'd like to connect to the original dome light wiring.
Don't want to cut off the connector so I'm hoping to find the male connector to plug into the existing female connector. Can anyone tell me what this type of connector is called and where I can find a male part?
can you id this connector? -- posted image.
tommy...
Gold - Posts: 1,901
Posted: December 07, 2010 at 7:59 PM / IP Logged
Not sure how you would look that up..? If it is the wire in the car , i would guess the dealer or junk-yard would have it...? You could always just peel back some of the insulation and make your connections there... leaving the harness in-tact...!  Is that the harness that plugs in to the "old" dome light...? Maybe you could use the portion from the dome-light and modify it to work for you(although thats alot of work)...
M.E.C.P & First-Class
Ween
Platinum - Posts: 1,368
Posted: December 07, 2010 at 8:54 PM / IP Logged
hi,
take the dome light assembly with you to a car audio shop. ask if they have any old adapter harnesses for radios lying around...i know i do. see if you can find a male terminal pigtail that matches the dome light terminal in thickness and width. remove terminal pigtail from housing, repeat twice...choose colors close to the Honda's colors, if lucky. use heat shrink or tubing to insulate the unprotected portion of the terminal. glue the three terminals together, hot glue is my favorite. make connections to the aftermarket overhead unit.
mark
oldspark
Gold - Posts: 4,913
Posted: December 07, 2010 at 9:29 PM / IP Logged
Might you want something like...
That's 2.54mm pitch (0.1"); there is also a 3.96mm version (~0.15").
They are common in PCs - eg, 2, 3 & 4 pin cooling fans.
EG - From Jaycar here, here & here (4-pin(sic) pictured).
PS - not modifying the existing wiring - priceless! (Long term - the extra trouble for translator interface wiring can be IMO well worth it!)
KPierson
Platinum - Posts: 3,527
Posted: December 08, 2010 at 12:10 AM / IP Logged
Don't cut the connector off - splice in to the wire 3" back from the connector.
Kevin Pierson
jeem
Posted: December 08, 2010 at 3:11 AM / IP Logged
Thanks oldspark and everyone else that posted. Splicing is the last resort. I've managed to install the monitor without making any irreversible mods to the van so I'm hoping to continue that.
I'll check out Jaycar for that connector oldspark.
oldspark
Gold - Posts: 4,913
Posted: December 08, 2010 at 4:00 AM / IP Logged
They are probably cheaper from scrap PCs or discarded fans....
Try computer shops etc.
There are also strips of "header pins" that can be used, eg:
Platinum - Posts: 13,720
Posted: December 08, 2010 at 5:48 AM / IP Logged
Desolder the socket from the old domelight.  Solder wires to the socket.  If you ever need to reinstall the original light, reverse the process.
tommy...
Gold - Posts: 1,901
Posted: December 08, 2010 at 2:04 PM / IP Logged
Guess... problem solved...! Yeah...I guess sometimes i just need to step back and think outside the box(or the shop in this case)...Doing this as an install...The last thing we would have time to do is look-up/order that part...But thats what you're here for ...eyyyy...?
tommy...
Gold - Posts: 1,901
Posted: December 08, 2010 at 2:06 PM / IP Logged
Mr. I...Hello friend
The domelight mod was what i was getting at in the post...Guess i just wasnt specific enough...HOW ARE YOU...?
Oh...BTW...Stripping the insulation back is far from irreversible...But sounds like you have a gameplan now...!
Sunday, October 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
